Artifacts left after using background erase tool in X6-64bit
philcarnahan
Post by philcarnahan »
I recently tried using the background eraser tool to remove a sky so I could use a different sky from the layer below. All went well, but when I was done I had a lot of pixel size white artifacts showing. They are not in the sky only layer. Further when I click on many of them, they disappear as long as the mouse is held down, then return as soon as the mouse is released. Others just don't change. The effect is the new sky has spots of "snow" that can't be erased. I've tried noise reduction on both layers with no change. The original sky being erased was a uniform light gray (boring). Replacement is an orange sunset sky with clouds. Just wondered if anyone had encountered this and found a fix. Win 7/64 bit with PSP-X6/64bit. ps: I did run Topaz Labs Detail on this image before the background erase. Thanks for comments and feedback!
Forriner
motherboard: ASUS Z170M-PLUS
processor: Intel Core i5-6400
ram: 16 GB
Hard_Drive_Capacity: 1250 GB
Monitor/Display Make & Model: Philips Brilliance 272b 2560 × 1440
Corel programs: PSP 2023
Re: Artifacts left after using background erase tool in X6-6
Post by Forriner »
It could be caused by any of the many Background Eraser Tool options (F4). Pixels outside the boundaries/tolerance won't be erased.
Read the Help to find out what each of the options does.
Assuming that the edges between the sky and the horizon have been succesfully erased, you could erase the scattered pixels with the normal Eraser tool, or select the sky with the freehand selection tool and press Delete. There are probably more ways, but just give it a try.
If that doesn't work, come back and tell us if you're working on multiple layers etc. and the Tool options settings.
philcarnahan
Thanks for the suggestions. I had pretty much explored the tool options and none had any effect. However switching to the eraser tool worked. A little more touchy since it is not edge sensitive, but I was 95% done so it didn't take too long to clean it up (if an hour is not much).
df
ram: 64gb
Hard_Drive_Capacity: 1 Tb
Post by df »
You need to start using Mask Layers. Please see http://forum.corel.com/EN/viewtopic.php ... 79#p239079
Regards, Dan
philcarnahan
Thanks for that suggestion. I looked at your tutorial and it obviously works well. I admit I'm struggling with using layers but am at a point I have to conquer it to improve. Many hours in front of computer coming.....
Thanks again
