[SOLVED] [X5] Removing all deleted files from thumbnails?
Shohreh
Post by Shohreh »
Hello
Even after a video file has been deleted from the hard disk, Corel keeps its thumbnail (with a yellow camera icon in the upper left-hand corner ) and displays the following error message when clicking on its icon:
"Original file [C:\Users\joe\ MAH01293.MP4] doesn't exist."
Short of clicking on the "Delete" button for every single thumbnail, is there a way to tell VS to just remove all the thumbnails of files that are no longer on the hard disk?
Thank you.
Re: [X5] Removing all deleted files from thumbnails?
Post by BrianCee »
Left click on the first one you want to delete - go to the last one you want to delete - hold down "Shift" as you select with a left click - all thumbnails will be selected - press delete - all thumbnails will be deleted.
or if it a complete library containing only thumbnails you want to delete - select the library from the library list and delete it.
Shohreh
Re: [SOLVED] [X5] Removing all deleted files from thumbnails
Post by Shohreh »
Thanks for the info.
