[SOLVED] [X5] Import MOV files?
Shohreh
Post by Shohreh »
Hello
I recorded a few video files with a cheap digital picture camera that look like this file:
Code: Select all
c:\>ffprobe.exe -i MVI_5908.mov
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'MVI_5908.mov':
  Metadata:
    major_brand     : qt
    minor_version   : 537331968
    compatible_brands: qt  CAEP
    creation_time   : 2014-07-04 14:02:36
  Duration: 00:00:12.75, start: 0.000000, bitrate: 11548 kb/s
    Stream #0:0(eng): Video: h264 (Constrained Baseline) (avc1 / 0x31637661), yu
vj420p(pc, smpte170m), 640x480, 9950 kb/s, 29.97 fps, 29.97 tbr, 30k tbn, 60k tb
c (default)
    Metadata:
    Stream #0:1(eng): Audio: pcm_s16le (sowt / 0x74776F73), 48000 Hz, stereo, s1
6, 1536 kb/s (default)
    Metadata:
VideoStudio can't import them. What would be the best way to convert those files so that they can be imported, preferable without an re-encoding?
Thank you.
Re: [X5] Import MOV files?
You cannot convert a video to a different format without re-encoding.
Do you have the latest version of QuickTime installed on your computer?
Shohreh
Post by Shohreh »
Thanks for the tip.
It works when convering just the audio and the container format:
Code: Select all
ffmpeg.exe -i input.mov -c:v copy -c:a libmp3lame -ab 128000 -ar 44100 -ac 2 -shortest -f mp4 output.mp4
