Plugin to reset horizontality ?
AfterShot Pro Plugins
FalCT60
Post by FalCT60 »
Hello,
As much of today's dSLRs have embedded tools as artificial horizon, I was wondering whether it would be possible to make a plugin that could help easily straightening bent pictures.
As for today, I paste zPerspector's grid to all my pictures, so I can more or less manually straighten those that need to, but I must admit this kind of feature would be really helpful.
J.-Luc
afx
operating_system: Linux
System_Drive: N/A
Video Card: FirePro 4900
Re: Plugin to reset horizontality ?
Post by afx »
Why do you need the grid?
Just use the straighten cursor on a horizontal or vertical line in the image?
cheers
afx
Hobgoblin
System_Drive: N/A
Post by Hobgoblin »
FalCT60 wrote:Hello,
J.-Luc
32Bit only, but Barna Keresztes Grid Plugin is still avaliable here along with the Zone Plugin.
http://www.kbarni.net/aftershot-pro-plugins.html
Works fine on ASP 2.0.3.25 and earlier.
Not sure why it is not on the Corel Page of Plugins though!
FalCT60
Post by FalCT60 »
Thanks both to your help. However, most of my photos are of my son on a play area, where I most of the time must be in kind of acrobatic positions, so the camera is never hroizontal and, worse, the tilt varies from a photo to another. :x
1- @afx : the trees and the sreetlights there are not straight and none of them has the same tilt. :evil: And there is almost never anything on the floor to help me. :twisted: So simply using the slider in eye sight is not really easy. The grid really helps me there. :cry:
2- @Hobgoblin : nice module, but it alters the final output if one forgets to deactivate it before export. :roll: I will have a deeper look at it anyway.
Thanks again,
J.-Luc
