PaintShop Pro X6 64-bit, SP2
It's been working for a week, but today when I launch it I get a dialog box saying "Corel PaintShop Pro X6 (64-bit) has stopped working" and the program ends. The corresponding event in the application log is:
Code: Select all
Faulting application name: Corel PaintShop Pro.exe, version: 16.0.0.3, time stamp: 0x530713cc
Faulting module name: msvcrt.dll, version: 7.0.7601.17744, time stamp: 0x4eeb033f
Exception code: 0xc0000005
Fault offset: 0x0000000000001213
Faulting process id: 0x100
Faulting application start time: 0x01cfb68a97a52ca6
Faulting application path: C:\Program Files\Corel\Corel PaintShop Pro X6 (64-bit)\Corel PaintShop Pro.exe
Faulting module path: C:\Windows\system32\msvcrt.dll
Report Id: e2c15bf2-227d-11e4-b32c-6805ca0a0e70Code: Select all
c:\>dir C:\Windows\system32\msvcrt.dll
Volume in drive C is Local Disk
Volume Serial Number is 4019-E818
Directory of C:\Windows\system32
12/16/2011 03:46 634,880 msvcrt.dll
1 File(s) 634,880 bytes
0 Dir(s) 380,064,337,920 bytes freeAnyone else run into this? I've opened a case with Corel since I still have 30 days support, but if I can fix it before they get back to me, even better.
Thanks.
Edit: Just tried launching 32-bit instead. It hasn't (yet?) crashed, but instead has apparently hung with zero CPU. One interesting (if possibly unrelated) side note... I always run PSP maximized. Now, it's about 70% of screen size and slightly off the screen to the upper right. Who knows - It might be that way normally and just maximizes itself before I notice...
