Render hangs in VS 5 : How can I find bad video file
delaluz
motherboard: HP Z210 work station
processor: xeon E31240 3.3ghz quad core
ram: 16gb
Video Card: nvidia NVS 300
Hard_Drive_Capacity: 6 TB
Monitor/Display Make & Model: Samsung 24" Syncmaster
Corel programs: Videostudio X9.5; Photoimpact X3
Post by delaluz »
I had a new 3 minute video project hand during the rendering phase. Based on searching the web it appears that if one of my 3 input video files had a bad "frame" that the render could hang.
Is there an easy way to scan a video to see if there is a bad frame?
Here's some backgraound:
A few month ago I completed a project where I rendered 20 different files with no problem. The input came from the same camera that I am having the render problems.
Two days ago I tried to render a simple project: 3 minutes long with one main video & two overlay videos. All three videos were shot with the same camera (which was used in the project I did 2 months ago).
I ran the render 4-5 times, rendering to another file "same resolution as first video option" and rendering to an iso. Each of the renders hangs Visual studio.
I re-booted my computer turned off all virus scans & backups & re-ran the render with the same hanging issue.
The last time I ran it I opened the task manager "processes" window. I observed the Visual Studio process using between 60% and 80% of the cpus. Than after a few minutes the usage dropped to 0% and Visual Studio became non responsive.
After the last hang I re-ran one of the renders from 2 months ago & it rendered fine.
The project that has the render problem is a simple 3 video (all shot with the same camera at same settings) project, no titles and only one transition, a fade to black at the end. I used the color correction for one of the input files.
Here's a printout from the Event Viewer Windows application log
Fault bucket , type 0
Event Name: AppHangB1
Response: Not available
Cab Id: 0
Problem signature:
P1: vstudio.exe
P2: 15.0.0.0
P3: 5149e750
P4: 6099
P5: 0
P6:
P7:
P8:
P9:
P10:
C:\Users\Berto\AppData\Local\Temp\WERC8E2.tmp.appcompat.txt
C:\Users\Berto\AppData\Local\Temp\WERD014.tmp.WERInternalMetadata.xml
These files may be available here:
C:\Users\Berto\AppData\Local\Microsoft\Windows\WER\ReportArchive\AppHang_vstudio.exe_171488b5cd29362cde9a981a5ea17d408eab6_14a6d5fc
Analysis symbol:
Rechecking for solution: 0
Report Id: 6224b778-1a47-11e4-947d-002215fd5e9c
Report Status: 1
canuck
operating_system: Windows 8.1
Re: Render hangs in VS 5 : How can I find bad video file
Post by canuck »
I would render each of the 3 source files (unedited) by itself to a video file. That should tell you if there is a problem with any of the source files and which one.
If there is no problem then create a project with only those 3 source files without any edits or mods.
If still no problem then add your edits but only make changes one at a time until you discover which edit causes the problem
delaluz
ram: 16gb
Post by delaluz »
canuck,
good idea
delaluz
ram: 16gb
Post by delaluz »
I was able to render each of my 3 source video files without VS hanging. However, I fixed my problem. When my original "render to file" hung it produced a partial video output file. I located the transition near the end of the partial file. I then adjusted by 2 seconds the cut that corresponded to the end of the partial file in my original project. I was then able to render my original project to a file & then create a DVD from the rendered file.
So, adjusting one edit "fixed" my render problem.
skier-hughes
Microsoft MVP
motherboard: gigabyte
ram: 4GB
sound_card: onboard
Hard_Drive_Capacity: 36GB 2TB
Post by skier-hughes »
Excellent news, thanks for letting us know.
