AfterShotPro2 2.0.0.133 amd64 worked
AfterShotPro2 2.0.3.25. amd64 not starting
/usr/bin/AfterShotPro2X64
Install Path: /opt/AfterShotPro2(64-bit)
LD_PATH: /opt/AfterShotPro2(64-bit)/lib:
XLIB_SKIP_ARGB_VISUALS: 1
./AfterShotPro: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.17' not found (required by /opt/AfterShotPro2(64-bit)/lib/libstdc++.so.6)
./AfterShotPro: /opt/AfterShotPro2(64-bit)/lib/libuuid.so.1: no version information available (required by /usr/lib/x86_64-linux-gnu/libSM.so.6)
Ubuntu 12.04 and ASP 64bit not starting
hannes_hab
- System_Drive: Z
- motherboard: ASUSTeK P8H77-I
- processor: Intel Core i7 3770K 3.5 GHz x 8
- ram: 16 GB
- Video Card: AMD Radeon R7 200 Series
- sound_card: Radeon HD 7700 7800 Sapphire
- Hard_Drive_Capacity: 2x250GbSSD
- Monitor/Display Make & Model: LG IPS 21:9 UltraWide 34UM95-P 3440x1440
- Corel programs: AfterShotPro 1, 2, (3)
regards Hannes
austria
Nikon D7000 + D70, Nikon P6000, Nikon P330 (use P7800) PanasonicTZ100, Vuescan
bibble 4, bibble 5, ASP mostly on Ubuntu 14.04 ( sometimes Suse Linux 11.4 or WIN10)
austria
Re: Ubuntu 12.04 and ASP 64bit not starting
...same here, was already mentioned in this thread http://forum.corel.com/EN/viewtopic.php?f=94&t=54034
Hello,
Well, rpm packages don't work either.
J.-L.
J.-L.
Code: Select all
sudo mv /opt/AfterShotPro2(64-bit)/lib/libstdc++.so.6.0.19 /opt/AfterShotPro2(64-bit)/lib/libstdc++.so.6.0.19.bak
sudo cp /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.16 /opt/AfterShotPro2(64-bit)/lib/see http://forum.corel.com/EN/viewtopic.php ... 59#p292059
At least we're all getting the same lib problem.
I'll say it one more time: Corel download section shows support for Debian although tech support says they support Ubuntu and not Debian. This appears to be just a libc version problem that could easily be resolved by compiling ASP2_x64 against Debian Stable (Wheezy) which would provide almost 100% compatibility with Debian Stable and other Debian based distributions from Wheezy on up. Market share suffers. On the other hand (aside from 5 fingers), I will assume the problem will disappear once Debian Testing is upgraded to Stable because of the later version of glibc .
