Bez and Mix3 for ASP2-64
AfterShot Pro Plugins
ferdinand-paris
motherboard: GA-X58A-UD3R
processor: 3.20 gigahertz Intel Core i7 960
ram: 4Gb
Video Card: NVIDIA GeForce 7300 GS
sound_card: Realtek High Definition Audio on-board
Hard_Drive_Capacity: 2500 Gb
Monitor/Display Make & Model: Eizo CG222W
Post by ferdinand-paris »
I provided my 64 bit plugins to Corel prior to the release of ASP2, as did some others, and I don't know why they haven't been released on the ASP plugins database. In the meantime you can download them from my website.
http://www.ferdinand-paris.com/bibble/B ... 64.afzplug
http://www.ferdinand-paris.com/bibble/M ... 64.afzplug
Tadjio
motherboard: Gigabyte
processor: Core i7 2.8GHz 860
Video Card: ATI HD5570
sound_card: Sound
Hard_Drive_Capacity: 2.5TB
Re: Bez and Mix3 for ASP2-64
Post by Tadjio »
Thanks.
Do you have a 64-bit version of asPlugInManager?
Does it handle a mix of 32-bit and 64-bit plugins?
(I don't know how they are differentiated in the User Plugins folder)
Tadjio
PSP X7.2 Ultimate user
AfterShot Pro 2.1 ASPirant
Windows 8.1 64-bit Pro
Canon EOS 100D, Olympus E-PM1 & iPhone 6
ferdinand-paris
ram: 4Gb
No I don't. I haven't seen anything much on asPlugInManager for ASP2. The 32 bit and 64 bit are separate installs (I assume you can install both) and I think you would want separate user folders, in part so that you could keep the plugins separated. At least that's my understanding.
Hobgoblin
operating_system: Linux
System_Drive: N/A
Post by Hobgoblin »
Many thanks for the updated plugins, both working fine with Linux as far as I can tell.
Any particular reason for Bez to have gained a Straighten Slider?
Let's hope you have cracked open the flood gates. :D
ferdinand-paris
ram: 4Gb
Hobgoblin wrote:Any particular reason for Bez to have gained a Straighten Slider?
I'm not sure how that straighten slider got in there. Well I do, I was trying to put a control in Bez to replicate the main straighten control to minimise tab-switching, but I never got it to work - as is clear when you try to use it. That slider should be commented out. I thought it had been. I guess I'll have to update that file.
The plugin developers have found the switch to 64 bit compiling difficult. I haven't even got my own Win-64 compile environment working - I had to rely on others for both Mac and Win and only did the Linux compile myself. I think that's the major hold-up, plus people have gotten busy and have lives.
ferdinand-paris
ram: 4Gb
I have uploaded a corrected version of Bez which leaves out the non-operational straighten slider. This is easy to fix if you have an earlier version of Bez - simply replace the .ui file with the earlier one. The one from the last version for ASP1 should be fine. Or you can download and install the corrected version.
