Changes and new batch settings are not saved
Bugs & Suggestions
Kneops
operating_system: Linux
System_Drive: N/A
motherboard: ASUS P8 Z68
processor: Intel i7 2600
Video Card: nVidia 450
sound_card: onboard
Hard_Drive_Capacity: 14 TB
Monitor/Display Make & Model: Dell U2713H & Spider4
Corel programs: ASP3
Post by Kneops »
Changing the name of a batch works and I can create new batches. But when I leave the program and start it again, they are gone...
Then I tried again with several batches and the program crashed. Then I tried again with only one new or changed batch, but is was not saved. So I can't use the batch?
afx
System_Drive: N/A
Video Card: FirePro 4900
Re: Changes and new batch settings are not saved
Post by afx »
Can you write to your user home directory? Try directly in the OS.
cheers
afx
Kneops
System_Drive: N/A
sound_card: onboard
Post by Kneops »
Yes I can. I just modifed a file inside the .Aftershot folder inside my /home/jack folder, and created and saved a new .txt file.
Kneops
System_Drive: N/A
sound_card: onboard
Post by Kneops »
I'm sorry, now I seem to be able to save a batch.
When I change the name of the batch in the front end of ASP, the name is saved after quiting and restarting the program. The nams is however not saved when doing the same thing from inside the settings window, after right click on the batch name. Then the new name is not saved.
afx
System_Drive: N/A
Post by afx »
I can reproduce the broken rename in the settings Window on Linux.
cheers
afx
