Hi there
I am using PSP8. I have attempted create the dripping blood effect using this tutorial http://www.pinoy7.com/psptutorials/9/drips/p2.shtml
Once I get to Step 3 where I am supposed to Floodfill the text with red, Floodfill has no effect. I have attempted to carefully follow all steps but I'm obviously missing something. Could someone give this a try and see if you can make it work past that point?
thanks very much
Lee
Dripping Blood effect
- hartpaul
- ram: 8 Gb
Re: Dripping Blood effect
No problems once the errors were corrected.
In step 1 the text setting "Floating = Selected" should read Creat as = Floating
In step 4 and Step 5, the opacity should be set to 100 to get clearer effects.
I have been using "Create as Floating", I will go through it again.. OK, got the word.. now the 3D effect.. OK, now New Raster Layer.. OK, now floodfill red.. NOPE nothing Floodfill will not apply.
I am now past the Floodfill stage, the problem was Opacity was set at 0. That setting was not mentioned in the tutorial. But now I am unable to erase the top layer. sigh.. trial and error time...
OK, I figured it out. thanks very much
- hartpaul
- ram: 8 Gb
Opacity again? It is a good idea to reset each tool to its default values each time you start using it.
Often when things don't happen as you are expecting it can be due to low opqcity (brushes and eraser), wrong layer selected, or in case of selection tools Remove rather than add or replace.
