I'm looking for a script to automatically resize images to 1200 pixels and add a copyright text to the lower right corner of the image.
The resize part is easy but copyright text disappears when resizing images of a different aspect ratio.
Jan
Look for Script to Resize, add © text (various aspect ratio)
Forriner
- motherboard: ASUS Z170M-PLUS
- processor: Intel Core i5-6400
- ram: 16 GB
- Hard_Drive_Capacity: 1250 GB
- Monitor/Display Make & Model: Philips Brilliance 272b 2560 × 1440
- Corel programs: PSP 2023
Re: Look for Script to Resize, add © text (various aspect ra
Have you tried this? Menu Image/Watermarking/Visible watermark... scales an image you use to watermark another image. The 'size' parameter is a percentage of the width (as far as I could see in a quick check) of the target image, to size the watermark. This would change the size of the watermark for each image if the width changes, so I suppose you wouldn't want to vary the width too much.
This could be put in the batch file.
Good luck, happy processing.
Jan Shim
- motherboard: ASUS ROG Maximus V GENE
- processor: Core i7-3770K 4.4GHz
- Video Card: nVidia GeForce 2GB GTX 660
- Monitor/Display Make & Model: Dell UltraSharp U2713H
I tried the watermarking approach and it didn't turn out very well. Plain text at a fixed font size works the best and cleanest.
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
You can use a PSPImage file for the watermark. Just keep the text as a vector and it should resize fine. At least it seemed to in my tests, I may not be shrinking or growing it as largely as you are but worth testing.
Otherwise, if you want a script to do it, you'll have to make the script intelligent.
You can take the image's new width and height, calculate size requirements, and place the text.
Jan Shim
Thanks! I managed to get the desired result with this script (works for landscape oriented images only)
from PSPApp import *
def ScriptProperties():
return {
'Author': u'',
'Copyright': u'',
'Description': u'',
'Host': u'PaintShop Pro',
'Host Version': u'16.00'
def Do(Environment):
# EnableOptimizedScriptUndo
App.Do( Environment, 'EnableOptimizedScriptUndo', {
'GeneralSettings': {
'ExecutionMode': App.Constants.ExecutionMode.Silent,
'AutoActionMode': App.Constants.AutoActionMode.Match,
'Version': ((16,0,0),1)
# Resize
App.Do( Environment, 'Resize', {
#'AspectRatio': 1.33333,
'CurrentDimensionUnits': App.Constants.UnitsOfMeasure.Pixels,
'CurrentResolutionUnits': App.Constants.ResolutionUnits.PixelsPerIn,
#'Height': 900,
'MaintainAspectRatio': True,
'Resample': True,
'ResampleType': App.Constants.ResampleType.Bicubic,
'ResizeAllLayers': True,
'Resolution': 72,
'Width': 1200,
'SharpnessValue': 100,
'AdvancedMode': True,
# VisibleWatermark
App.Do( Environment, 'VisibleWatermark', {
'Opacity': 50,
'Placement': 1,
'Stretch': 18,
'Emboss': 0,
'Foreground': u'C:\\Program Files (x86)\\Corel\\Corel PaintShop Pro X6\\Languages\\EN\Scripts-Trusted\\Watermark.pspim'\
u'age',
return {
'Author': u'',
'Copyright': u'',
'Description': u'',
# Resize
#'Height': 900,
'Resample': True,
'Resolution': 72,
'Width': 1200,
# VisibleWatermark
'Opacity': 50,
'Placement': 1,
'Stretch': 18,
'Emboss': 0,
u'age',
- hartpaul
- ram: 8 Gb
Free program Irfanview allows bulk resize of images both portrait and landscape based on longest side set to say 1200 pixels. Also allows placing of plain overlay text in any font present at bottom left, right, top or middle.
Jan Shim
Thanks. I use Faststone's Image Viewer when I need to batch process. This script helps me automate the occasional single image I want to share on social media.
