I am using AfterShot Pro on 30 day trial. No problems but I finally got round to trying it on a Nikon NEF raw file from a D7000. I usually use right click open with and that has worked on several other camera raw files but for some reason it starts up but doesn't show the file. If I use the menu and file open the same thing happens.
Any clues? Not long to go before the trial ends and I have to make my mind up.
John
After Shot Pro on OpenSuse 12.3 KDE Linux NEF's
afx
- System_Drive: N/A
- Video Card: FirePro 4900
Re: After Shot Pro on OpenSuse 12.3 KDE Linux NEF's
D7000 should be fine.
But has thins thing been mangled by Nikon software? Is it straight out of cam?
cheers
afx
cheers
afx
Straight out of the camera. They open without any problem with other raw converters.
Not too happy with the results of those though which is why I'm trying ASP.
John
John
afx
- System_Drive: N/A
I just downloaded sample D7000 files from DPReview and imaging-resource.
Both work fine here, the log file shows:
cheers
afx
Code: Select all
92.405: Scanning file "/tmp/D7000FARI00100.NEF"
92.408: Importing: "/tmp/D7000FARI00100.NEF"
92.413: defaults: "DefaultRaw.xmp"
92.507: Scanning file "/tmp/DSC_1875.NEF"
92.508: Importing: "/tmp/DSC_1875.NEF"
92.988: QSqlDatabasePrivate::addDatabase: duplicate connection name '3423595868', old connection removed.
92.989: Adding master versions
92.990: Extracting RAW data: "/tmp/D7000FARI00100.NEF"
92.995: Extracting RAW data: "/tmp/DSC_1875.NEF"
92.995: Decoding RAW data: "/tmp/D7000FARI00100.NEF"
93.1: Decoding RAW data: "/tmp/DSC_1875.NEF" afx
Dutchmm
- System_Drive: N/A
- motherboard: Asus 97
- processor: Intel i7 4785T
- Video Card: Onboard Intel
- sound_card: Intel AC97
- Hard_Drive_Capacity: 2.5TB
- Monitor/Display Make & Model: Philips 28"
- Corel programs: ASP 3 Pro (and 2 and 1 before)
When I first read John's message, I wondered if perhaps there was a case problem with the extension. The other question that occurs to me is whether he was trying to read the raws in a directory into which the other converters had written an xml file. I had that problem back in the days when I was trying out Bibble against other raw converters. Try reading the .NEFs from an otherwise empty directory?
