Managing proxy files in X7
qtrim
motherboard: ASUS P5QL PRO 775 P43
processor: Intel Core 2 Quad Processor Q9550 2.83GHz 1333MHz
ram: 4GB
Video Card: NVIDIA GeForce 9400 GT
sound_card: Onboard Asus Audio
Hard_Drive_Capacity: 2TB
Monitor/Display Make & Model: Samsung T260HD 25.5-Inch LCD
Post by qtrim »
I finally upgraded to X7. I like it.
I wanted to share what I found about saving access to the proxy files X7 creates and a few tips:
If you set X7 to 'auto generate proxy template' is will create files with a .upx file name , which can only be used by X7, not played by themselves. However, if you uncheck the auto setting you can choose pretty much whatever file format you'd like. I chose this setting for a balance of file size and performance:
MPEG-4 Files
24 bits, 720 x 480, 30 fps
Frame-based
H.264 Main Profile Video: 2000 Kbps
44100 Hz, 16 Bit, Stereo
MPEG AAC Audio: 128 Kbps
This creates a file that is about 25% smaller than the original 1920x1080. The best part is, it has a standard file extension and can be played by any player. So in the process of creating a proxy, you also get a smaller downsized file, which may come in handy outside of VideoStudio. On my system, X7 can create these in a little better than real time.
The data file that contains the proxy file info is called uvProxyMgr_vstudio.dat and is located in the C:\Users\YOURNAME\AppData\Roaming\Ulead Systems folder. The AppData folder is hidden by default in Windows7, so you'll have to unhide it to navigate to it the first time. Note: If any of the source or proxy files have been renamed or removed, X7 will erase this file and thus you’ll lose access to all your previously created proxy’s (this is quite irritating). So, if you’re using a removable drive, you must make sure it is attached and accessible before launching the program.
If you create a bunch of proxy files that you’ll need access to over several sessions, be sure to back up the uvProxyMgr_vstudio.dat file each time you create more proxy’s. It can be restored at any time to the \Ulead Systems\ folder and X7 will once again be able to see and use the files.
Here’s a cool tip: This can also be useful if you edit on two different machines as I do, using a portable drive to move between machines. On both systems, set X7 to created the same type of proxy file; set both systems to use the a proxy folder on the removable drive; and then just move the uvProxyMgr_vstudio.dat file any time you plan to switch systems.
If you never use the proxy’s, then this is all pointless, but I wanted to share for those who are frustrated by the way X7 looses your proxy files access. Bottom line is, backup that uvProxyMgr_vstudio.dat file each time.
Using VideoStudio since old Version 7. Currently using X10.
