can anyone help me to move some old smartscene templates from version x4 to x7. It used to be you just moved the UFO file and its associated configuration settings, but now it seems I need a jpeg file which I cannot find.
Moving menu templates from X4 to X7
mandm
- motherboard: Sony Vaio
- processor: 2.20 gigahertz Intel Core2 Duo
- ram: 4gb
- Video Card: Mobile Intel 4 Series Express Chipset
- sound_card: Intel High Definition Audio HDMI
- Hard_Drive_Capacity: 300gb
- Monitor/Display Make & Model: Generic PnP Monitor
Re: Moving menu templates from X4 to X7
As far as I can tell all DVD Menu templates used with X4 are also used with X7
So why are you trying to move them?
X4 also has Jpg image files associated with the templates.
Give a particular example so we can compare
mandm
- ram: 4gb
Sorry, I just remembered that it is a template that I use all the time and had already moved it from videoplus 11.
The files a I moved and which work in X4 are :-
05vs_OneSO5_W_MS Configuration settings
05vs_OneSO5_W.ufo UFO file
The files are in Content/Menu Templates/16x9/One Scene Button in both video 11 and X4. There is obviously a picture associated with these files but I cannot find it anywhere.
I do not know if you need any other information please let me know
I have a number of menu templates which I have moved up into X7 which do not have jpeg images with them and they all seem to work OK without problems - have you actually tried it.
In any case is that template not already in X7 - is it not the
07_OneS05_W.ufo
07_OneS05_W_MS.ini
set of files - the first number just indicates which version it was actually released with and changes between versions but the template remains the same.
can you not 'borrow' a copy of the jpeg from there - or if it is not the same then open your favourite in X4 and take a screen grab and create your own jpg.
07_OneS05_W.ufo
07_OneS05_W_MS.ini
