I have a several large video files that I render daily.
I was wondering if their is some way to have Videostudio run via script?
That way I could queue my big jobs at the end of the day and have them render overnight.
Thanks,
RIch
Can we use scripts to render in V7
richflorida
- motherboard: Gigabyte GA78LMTUSB3
- processor: 4.00 gigahertz Intel I7-4790K
- Video Card: AMD Radeon R9 200 Series
- sound_card: AMD High Definition Audio Device
- Hard_Drive_Capacity: 3.5TB
- Monitor/Display Make & Model: DUAL <Acer G276HL [Monitor] (27.2")>
Re: Can we use scripts to render in V7
You can't use scripts as such in VideoStudio - but depending on exactly what it is you need to do you may be able to use "File >> Batch Convert"
richflorida
What I am running into is a situation where I have many projects that I work on every day. If I render directly after getting each project ready I lose approximately 3-5 hours out of my day. What I want to do is edit and get each project ready and then batch submit the rendering at night. That way I can do the creative work during the day and leave the rendering for nights.BrianCee wrote:You can't use scripts as such in VideoStudio - but depending on exactly what it is you need to do you may be able to use "File >> Batch Convert"
Thanks,
Rich
richflorida
I was able to change the template resolution to what I need. I did a trial with a few small files and it looks good. I will try some larger files tomorrow.rwernyei wrote:http://forum.corel.com/EN/viewtopic.php ... 4&p=290169&
Many thanks to everyone who helped. This render time has been a huge problem for me, it is such a relief to have a solution. This really should be in the user guide.
Rich
Can you not see "MPEG transport stream files" in the "Save as type" drop down ?
richflorida
I was using the mpeg-4 save as but the resolution was too low. I had to make a new profile for the 1920x1080 resolution.BrianCee wrote:Can you not see "MPEG transport stream files" in the "Save as type" drop down ?
Everything works great now. Thanks for the help. You all have given me back 3-5 hours of my work day!
Rich
