Max. Photo Size for Panorama-Pictures?
250 Megapixel ? only for 64bit ASP? I think its not working here (linux).
What about the longer side?
What is the maximum Size of 32bit ASP2 ?
50 Megapixel ?
20000 pix - for the longer side?
I see some problems with panoramas and z-Frame plugin.
Longer Side max 10240 still? - when using plugins?
Is there a timeline for the plugins - when will they be 64bit?
Are the plugin developers (especially Z-Frame - tin.tin ...) working on 64 bit plugins?
hannes_hab
- System_Drive: Z
- motherboard: ASUSTeK P8H77-I
- processor: Intel Core i7 3770K 3.5 GHz x 8
- ram: 16 GB
- Video Card: AMD Radeon R7 200 Series
- sound_card: Radeon HD 7700 7800 Sapphire
- Hard_Drive_Capacity: 2x250GbSSD
- Monitor/Display Make & Model: LG IPS 21:9 UltraWide 34UM95-P 3440x1440
- Corel programs: AfterShotPro 1, 2, (3)
regards Hannes
austria
Nikon D7000 + D70, Nikon P6000, Nikon P330 (use P7800) PanasonicTZ100, Vuescan
bibble 4, bibble 5, ASP mostly on Ubuntu 14.04 ( sometimes Suse Linux 11.4 or WIN10)
austria
jknights
- motherboard: Apple
- processor: Intel 3.08GHz Dual processor Quad Core
- ram: 24GB
- Video Card: ATI Radeon X1600
- sound_card: Intel HDA
- Hard_Drive_Capacity: 6TB
- Monitor/Display Make & Model: Apple Display
Re: Max. Photo Size for Panorama-Pictures?
The file limit that was in ASP v1 has been moved upwards. I dont knwo what teh maximum file size is but I tested it on Mac OSX and I loaded a 250MB file into ASP v2 (32bit). I dont expect that it is different for 64bit.
Still learning after all these years!
hannes_hab
- System_Drive: Z
- ram: 16 GB
250 Megapixel are 25.000 x 10.000 pix - i cannot open a file with 25.000 x 6.482 pix - 9.2 MB (.jpg)
(linux)
(linux)
regards Hannes
austria
austria
jknights
- ram: 24GB
Sorry I just looked at my test notes.
I tested this.... "Remove 30MB of file size limitation for TIFF files". I can confirm that this has been removed as I tested with a 55MB, 90MB and 250MB TIFF.
I will take a further look at "Set 250 megapixels as maximum image support (around 16,000 x 16,000 dimensions)" on my Mac machine and report back.
jknights
- ram: 24GB
OK I just made a 240MPixel file in Photoshop CS6. Saved as PSD and jpg format and retested that it loads in Photoshop CS6. All OK. The saved file is a 8bit JPG of size 60.4MB.
The file is NOT loaded by either 64bit or 32bit version of Corel ASP v2.0.2.10
I did not do a regression test to see how far back I need to go but I did test a 100MPixel file and it doesnt load that either.
