Colour not included in preset?
WillyV
Corel programs: Paint Shop Pro
Post by WillyV »
I'm a longtime user of PaintShop Pro but have just recently started using presets. I defined a few presets for the rectangle tool and would like to have a black and a red rectangle with different line properties.
However, it seems the colour of the lines are not saved as part of the preset, Is this intentional or a bug?
Willy
(Edit: I'm using the latest SP2 version of PaintShop Pro 64-bit)
trueblue
Moderator
motherboard: ASUS Z97M Plus
processor: Intel Core i7-4790 CPU 3.60 GHz
ram: 12GB
Video Card: NVIDIA GeForce GTX 750
sound_card: NVIDIA High Def Audio Realtek High Def
Hard_Drive_Capacity: 1.740GB
Monitor/Display Make & Model: Benq E2420HD 24" wide x 2 monitors
Corel programs: PSPX8-VideoStudio-AfterShot
Re: Colour not included in preset?
Post by trueblue »
When using the preset did you have Retain Style ticked? In order to have the shape drawn as you saved it, this box must be ticked.
~~~~Maureen~~~~
Creative-Designs
Free! PaintShop Pro Tutorials
WillyV
Post by WillyV »
trueblue wrote:When using the preset did you have Retain Style ticked? In order to have the shape drawn as you saved it, this box must be ticked.
As far as I can see the Retain Style check box is only available for Preset Shape (callouts, arrows etc.), not for the Rectangle tool.
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Post by LeviFiction »
Presets on the tool options palette are only for the options in the tool options palette.
If you want to draw a rectangle with all of the same settings including color, you need to export it to a preset shape. Make sure the vector object is given a descriptive name inside the layers palette. Select the object then go to File -> Export -> Shape and give it a filename.
Once saved you can select it from the preset shapes tool. It will still be a rectangle, editable with the rectangle shape tool, and it will contain all of your settings as well as color. Also with "retain style" turned off you can change the colors. But this only works with preset shapes, not presets.
WillyV
Post by WillyV »
LeviFiction wrote:If you want to draw a rectangle with all of the same settings including color, you need to export it to a preset shape.
Aha, exporting to a preset shape was the hint I needed. :-) Thanks!
