Batch processing of JPG images
B24Mike
motherboard: Z77A-G45
processor: 3.40 gigahertz Intel Core i7-2600K
Video Card: NVIDIA GeForce GTX 570
Hard_Drive_Capacity: 7.686TB
Monitor/Display Make & Model: Dual 28" DVI monitors - Hanns.G iH283H
Post by B24Mike »
I have digital scans of about 75,000 pages of World War II documents from the 2nd Air Division (B-24 units in England). These images were converted from 16mm microfilm to Adobe PDF's (54 reels of film) which I have converted into JPG images. Most of the images are uniformly dark and can be made more readable by applying contrast and brightness settings. I tried following the script creation process, but when I try running the script during batch processing, I have to manually select the script file and apply it. Can you give me the steps that I need to follow to be able to run a contrast/brightness script against the contents of a folder with up to 2,100 JPG images?
Tony Lenton
motherboard: Intel DH55TC
processor: Intel Core i5 3.20 GHz
ram: 12GB
Video Card: GeForce GTX 1060
sound_card: On board Realtek High Def Audio
Hard_Drive_Capacity: 4500 GB
Monitor/Display Make & Model: Lenovo S27i
Corel programs: PSP X6 PSP2020
Re: Batch processing of JPG images
Post by Tony Lenton »
Hi Mike
First create a new folder to save the modified jpgs.
From the File menu select "Batch Process"
Browse to the folder that has the images that you want to process and select them all.
From the "Batch Process" panel select the script that you want to run.
Select the "Save mode" that you want.
Under "Save Options" navigate to the new folder that you created for saving the new files.
Click on the Start button.
Radim
ram: 4GB
Monitor/Display Make & Model: 27 inch
Post by Radim »
PaintShop Pro is not "best" for it. Believe me. I already spend a lot of time with such groups of images through the years... :(
The problem with PSP is that it does't report sometimes "incorrect" processing.
So you have to manualy check result of all processed images.
But, you can try insteed look on:
* http://www.xnview.com/en/xnview.php
* or better http://www.xnview.com/en/xnconvert/
Or another free tools:
* http://www.irfanview.com/
* http://www.faststone.org/FSViewerDetail.htm, Free for Home users
* http://www.highmotionsoftware.com/products/imbatch
B24Mike
Post by B24Mike »
Guys: Thank you very much for your input.
Radim: I really like the link to IMBATCH. I downloaded the tool and immediately applied it to a sample and it worked just fine. As the unit historian and webmaster for the World War II 445th Bomb Group (http://www.445BG.org), I just wanted to say that the image cleanup of records will make a nice addition to the website. Thanks again for your recommendation.
