Photos Don't Show Up in ASP2 After Output
Bugs & Suggestions
dsigman
motherboard: ASUS A78M-A
processor: AMD A8 6600K
ram: 8 GB
Video Card: ASUS R7 250X
sound_card: AMD High Definition
Hard_Drive_Capacity: 1 TB
Post by dsigman »
I was able to output files as Tiffs to Topaz PhotoFx Lab. However, after making the edits in Topaz the resulting images did not show up in the ASP file system. The images were available in Windows Explorer, Photoshop Bridge and PSP X6.
afx
operating_system: Linux
System_Drive: N/A
Video Card: FirePro 4900
Re: Photos Don't Show Up in ASP2 After Output
Post by afx »
Press F5...
cheers
afx
dsigman
ram: 8 GB
Post by dsigman »
afx wrote:Press F5...
cheers
afx
I tried that but with no success.
afx
System_Drive: N/A
Post by afx »
Are you using a catalog?
cheers
afx
dsigman
ram: 8 GB
Post by dsigman »
afx wrote:Are you using a catalog?
cheers
afx
No
afx
System_Drive: N/A
Post by afx »
That is weird then. Anything about the generated file in the log file?
cheers
afx
dsigman
ram: 8 GB
Post by dsigman »
afx wrote:That is weird then. Anything about the generated file in the log file?
cheers
afx
Sorry, I don't know what you mean by the log file.
afx
System_Drive: N/A
Post by afx »
In your AfterShot user folder there is a log file named AfterShotPro.log.
The location of your user folder can be found via Help->System Info.
When I run the external command (using gimp as the editor I get the following entries:
Code: Select all
7418.291: launching:  "/usr/bin/gimp"   ""/archive/pic/Bibble-Test/t0-raw/AFX_2436_edit.tif""
7418.301: Starting import with settings :  "<x:xmpmeta xmlns:x="adobe:ns:meta/" x:xmptk="XMP Core 4.4.0">
 <rdf:RDF xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#">
  <rdf:Description rdf:about=""
    xmlns:bibp="http://www.bibblelabs.com/BibblePrivate/5.0/"
   bibp:MoveCopy="2"
   bibp:LibraryLoc=""
   bibp:LibraryID="1631"
   bibp:LibraryUuid="{62a7db03-8945-4894-9c1c-7ef6f17df829}"
   bibp:Organize="0"
   bibp:FolderTemplate=""
   bibp:Recurse="false"
   bibp:RenameOn="false"
   bibp:FileTemplate=""
   bibp:ImportPath="/archive/pic/Bibble-Test/t0-raw"
   bibp:KeywordList=""
   bibp:FolderFilter="AFX_2436_edit.tif"
   bibp:QueueName=""
   bibp:QueueType="0"
   bibp:QueueOnlyNewFiles="false"
   bibp:JobName=""
   bibp:PresetList=""/>
 </rdf:RDF>
</x:xmpmeta>
7418.302: Adding master versions
7418.575: Adding master versions
7418.575: Scanning file  "/archive/pic/Bibble-Test/t0-raw/AFX_2436_edit.tif"
7418.579: Importing: "/archive/pic/Bibble-Test/t0-raw/AFX_2436_edit.tif"
7418.586: defaults:  "DefaultRendered.xmp"
7419.70: Adding master versions
7514.488: Starting import with settings :  "<x:xmpmeta xmlns:x="adobe:ns:meta/" x:xmptk="XMP Core 4.4.0">
   bibp:MoveCopy="2"
   bibp:LibraryLoc=""
   bibp:Organize="0"
   bibp:KeywordList=""
   bibp:QueueName=""
   bibp:QueueType="0"
   bibp:JobName=""
 </rdf:RDF>
</x:xmpmeta>
7514.489: Adding master versions
7514.617: Adding master versions
7514.618: Scanning file  "/archive/pic/Bibble-Test/t0-raw/AFX_2436_edit.tif"
7514.624: **** Found an old file in the import "/archive/pic/Bibble-Test/t0-raw/AFX_2436_edit.tif"
7514.658: Removed child refs
7514.702: Importing: "/archive/pic/Bibble-Test/t0-raw/AFX_2436_edit.tif"
7514.710: defaults:  "DefaultRendered.xmp"
7514.983: QSqlDatabasePrivate::addDatabase: duplicate connection name '3423595868', old connection removed.
7514.994: Adding master versions
Before AS forks off the external editor I already see the TIFF file show up underneath the orginal NEF.
And once the external program saves the changes, AS automatically shows the changes on my box.
cheers
afx
lathspell
Post by lathspell »
You're sure that you have made the right settings when installing ASP 2? During the installation you can choose which file formats ASP 2 will display (RAWs, TIFFs, JPEGs) - perhaps you've missed the checkbox for TIFFs?
ETA: AFAIR unfortunately you can't change these settings after the installation. In Bibble 5 there was a section for this in the preferences settings, but with ASP 1 that section had been gone.
dsigman
ram: 8 GB
Post by dsigman »
lathspell wrote:You're sure that you have made the right settings when installing ASP 2? During the installation you can choose which file formats ASP 2 will display (RAWs, TIFFs, JPEGs) - perhaps you've missed the checkbox for TIFFs?
I tried that but no luck. The output works fine if I use one of the presets. e.g. 16 bit Tiff but not if I output to a program. <ctrl E> works fine.
dsigman
ram: 8 GB
Post by dsigman »
afx wrote:In your AfterShot user folder there is a log file named AfterShotPro.log.
Code: Select all
   bibp:MoveCopy="2"
   bibp:LibraryLoc=""
   bibp:Organize="0"
   bibp:KeywordList=""
   bibp:QueueName=""
   bibp:QueueType="0"
   bibp:JobName=""
 </rdf:RDF>
</x:xmpmeta>
   bibp:MoveCopy="2"
   bibp:LibraryLoc=""
   bibp:Organize="0"
   bibp:KeywordList=""
   bibp:QueueName=""
   bibp:QueueType="0"
   bibp:JobName=""
 </rdf:RDF>
</x:xmpmeta>
cheers
afx
Haven't found the file yet
lathspell
Post by lathspell »
dsigman wrote:...but not if I output to a program. <ctrl E> works fine.
Does the external editor (Topaz) perhaps use a TIFF compression method which ASP can't handle? I.e. ASP 1 doesn't show 8-bit-JPEG-compressed TIFFs here ... (Can't check with ASP 2 since my trial period is over.)
dsigman
ram: 8 GB
Post by dsigman »
The problem occurred even whenoutputting to PSP x6 although there is no problem if PSP is external editor.
lathspell
Post by lathspell »
Ok, then I give up too.
dsigman
ram: 8 GB
Post by dsigman »
lathspell wrote:Ok, then I give up too.
Thanks for trying
