Any way to alter the color of preset shapes?
pdxrjt
- processor: Intel Core i7 - 4.2 GHz
- ram: 32 GB
- Video Card: NVIDIA GeForce GTX 1080
- Hard_Drive_Capacity: 10TB Int.
- Monitor/Display Make & Model: Acer 32 inch x2
- Corel programs: Paint Shop Pro 2018
In the past I have drawn colored arrows using the line tool with an arrow. I wanted to use the preset shape arrows but didn't see a way of changing the color from basic black, which didn't show up well in this particular photograph. Anyway of changing the color from black (aside from doing a selection and using the fill tool or something.) TIA
Adverts for Corel products when you close PSP don't bother me.
Zacabeb
- motherboard: ASUS B450-F
- processor: AMD Ryzen 5 3600
- ram: 16 GiB
- Video Card: nVidia GeForce RTX 2060
- sound_card: RealTek Integrated Audio
- Hard_Drive_Capacity: 3 TB
- Monitor/Display Make & Model: Philips 236V4
- Corel programs: PaintShop Pro X6, PaintShop Pro 2021
Re: Any way to alter the color of preset shapes?
When you've selected the Preset Shape tool, make sure that the checkbox "Retain style" is unchecked. Then you can select the colors you want for the outline and fill as usual in the Materials palette.
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
Zacabeb's way is the best. Since it's quick and up front.
If you still end up wanting to update it later. Then it needs to remain a vector.
If you keep the preset shape as a vector you can also edit the colors after the fact. Just select the shape with the pen tool or the pick tool and select new colors from the materials palette. Or you can double click on the shape and a properties dialog box will come up allowing you to change the line style, the width of the stroke, and the colors.
There is always a way to edit a vector after the fact, but only if you create it as a vector.
pdxrjt
- ram: 32 GB
Thanks, just tried it and worked like a charm. Appreciate the knowledge and time.
