Unspecified error [5:0:0]
The Hessen
Post by The Hessen »
Having a heck of a time to burn to disk. I keep getting the following error: Unspecified error [5:0:0]
I have version x7.
I tried the suggestions on : http://corel.force.com/index/articles/e ... source=kba
6-24-2014 3-33-33 PM.jpg (9.35 KiB) Viewed 1699 times
Re: Unspecified error [5:0:0]
Post by BrianCee »
Errors in the burn module can often be worked around by breaking the process down into a number of separate steps and checking at each stage.
First on completion of editing go to "Share >> Create video File" and render a DVD compliant mpeg-2 file - - Test it
when you go to the burning module empty the time line and make sure you import the new and tested mpeg file - render to "Disc Image file" (.iso)
test the iso by playing it in the free VLC image player - if good use a free disc image burner (included in later versions of VideoStudio) to burn the image to disc.
