I have a 20 second clip. I want to COPY from 7 seconds to 13 seconds from the clip. I want to paste that section just after the 13 second mark.
Basically I want to show seconds 7 - 13 twice.
Paul
parker, co
cut and paste in existing clip
56belair
- motherboard: ASUSTeK COMPUTER INC. P8H77-M Rev X.0x 100MHZ
- processor: 3.40 gigahertz Intel Core i7-3770
- ram: 32GB
- Video Card: NVIDIA GeForce 8400GS
- sound_card: AudioBox 1818VSL Audio
- Hard_Drive_Capacity: 2x 1000 GB
- Monitor/Display Make & Model: 2x LG 24EN33
Paul Jarrett
Parker, Colorado
Corel Video Studio Pro x5
Parker, Colorado
Re: cut and paste in existing clip
Cut the clip at the 7 second mark. Right click the new second part of the video and select Copy. Then Paste it at the 13 second mark i.e. at the end of the second clip. And don't worry. The first cut will not be visible in the final rendered video unless you insert a transition over it.
canuck
Since it is a 20 sec clip, you will need two cuts: one at 7 secs and another at 13 secs. Now switch to the Storyline and you should see 3 thumbnails. Since the middle one (from 7 to 13 secs) is the one you want to duplicate, select it, press CTRL-C to copy it and the select the 3rd clip and press CTRL-V. The 7 to 13 sec clip should now show twice.
56belair
- ram: 32GB
I finished it. Thanks for the response.
Is x7 much of a jump from x5?
Paul Jarrett
Parker, Colorado
Parker, Colorado
Check out the differences between X5 and X7 here :-
http://www.videostudiopro.com/docs/prod ... son-en.pdf
