@R Frydryck: Thank you for the Reply! The color noise you see, when viewed at higher magnification, resembles the artifacting caused by heavy lossy compression like used in JPeG, so I called it atrifacting. Probably not the correct terminology, but that's what it looks like. Canon has been pretty good about providing software and firmware updates to DPP, my camera, and the lenses I use, in fact, the last updates I downloaded addressed both chromatic aberration and luminance for both of my primary lenses. If you haven't looked at the latest DPP release, check it out. They've added quite a bit. Nothing like these programs we are discussing, but not bad at all, JPeG adjustment as well as RAW comes to mind first off.
I'm like you, I've been using Corel products since Draw 3, and I own PhotoImpact X3, PSP X6, WordPerfect, etc., so I jumped right on ASP 2 without doing the free trial, I know, my bad. I didn't see the problems until after I bought it
I did notice the same problems in PaintShop Pro X6 RAW conversion as that of ASP 2, probably the same conversion.
Thanks you for the heads up on ACDsee, I used that years ago (2004), but it just dropped off of my radar.
-FD
