Is it possible to create Duotones with PSP X6? When I used PS CS2 I was able to create a selenium tone which enriched the greys and blacks by adding a slight purplish tone to the image. I was able to adjust the amount of tone using either curves or levels which gave you a fine level of control.
I would like to do the same thing with X6 if possible so anyone with a great deal of knowledge about PSP please advise me. Thank you.
Tim
Duotones
raven4ns
- ram: 12gb
- Hard_Drive_Capacity: 1TB
- Corel programs: PSP
Duotones
Regards
Tim
The measure of a man is not how many times he gets knocked down...but how many times he gets back up.
https://www.flickr.com/photos/44673530@N04/
Tim
LindaSue
- motherboard: Gigabyte
- processor: 2.71GHz AMD Athlon II X2 215 processor
- ram: 3 GB
- sound_card: Realtek AC97 Audio [onboard]
- Hard_Drive_Capacity: 1320 GB
- Monitor/Display Make & Model: Asus MX279 HDMI 27-inch
- Corel programs: Paint Shop Pro X2, X4, X6
Re: Duotones
Tim, you posted about the same topic last year here:
http://forum.corel.com/EN/viewtopic.php ... um#p276938
Using Paint Shop Pro versions 5, 6, 7, 8, 9, 12, 14, 16
raven4ns
- ram: 12gb
Re: Duotones
Yes, and at the time I was hoping to be able to use curves or levels to adjust the duotone or quadtones but could not. I have Topaz B&W and couldn't do it with that either. The only way I could do it was through PS CS2, in the meantime I was hoping there might have been some changes to allow it to be done in PSP X6 or the updated Topaz B&W filter so I was asking the question again.
Tim
Tim
Regards
Tim
Tim
Kathy_9
- Hard_Drive_Capacity: 2TB
Re: Duotones
Why not use Quad Tone under Finishing Touches in Topaz B&W? There are four colors that you have control over and can change to suit your image.
raven4ns
- ram: 12gb
Re: Duotones
Hi Kathy,
I tried using PS using the channels but I got so frustrated that I gave up. It was after that I accidently came across the presets in PS. I played with the curves chart and found that I could get the general look I wanted then I used levels to fine tune it. That method was the easiest to use for me at least and it was shortly after that my computer had a hissy-fit and I had to buy a new computer but had lost all my images and data. My son and I thought we had backed everything up but it was only a partial b/u. When he changed jobs I lost my access to PS and as this is a hobby I couldn't justify the expense of buying PS.
I've tried using channels but I could never get the hang of getting the right recipe so it looked the way I wanted. I struggle with colors it seems even color images which perhaps explains why I enjoy B&W so much....lol.
Tim
Tim
Regards
Tim
Tim
