Working Directory Problem Version 9
CalifDude
Post by CalifDude »
I had previously rendered a movie and went back to burn to a DVD. I received an error msg about not having enough room in my working directory. The working directory was the one set by the defaults on my C drive. I confirmed that the working directory was empty. I went into preferences and changed my working directory to my external hard drive, drive E. This made no difference, and the error msg is still referencing my working directory on my C drive even though I changed it to my E drive.
At this point I'm unable to create my DVD until this has been resolved. Any suggestions?
Post by Trevor Andrew »
For some reason Ulead have used 2 default working folders when using VS 9
One for capture and editing as normal and a second in the burner module.
This folder can be changed from the burner module.
Select the icon adjacent to the ‘cogwheel ‘ then preferences, notice the working folder is different to the edit working folder.
or
Press F6 from the burner module
Why Ulead have done this I do not know, but there may be a good explanation ???????????????????
Trevor
