I'm totally mystified, but the CR2 raw files that I view in ASP2 are significantly underexposed and grainy, versus what I see in Canon's own DPP. I've attached a side by side example.
I've completely wiped ASP2 and reinstalled from scratch, applying the latest patch. DPP is installed under WINE. I viewed them both, side-by-side, on the same monitor (color calibrated).
When I took the image, I checked the histogram on the camera, and even though it was dark, it should have been good. The histogram I see in DPP looks like what was shown on the camera's own viewscreen. The ASP2 histogram is very blocky.
ASP2 raw looks really, really bad.
I also did some images where I shot RAW + JPG. Guess what ? The JPGs look fine in ASP2, it's the RAW CR2s which are terrible.
Right now, ASP2 is not usable for much of my work.
[UPDATE: 6/15. I've gone ahead and run ASP2 from a live Ubuntu instance (14.04), to be sure that I didn't have a misconfiguration. I checked the same set of test images, and the results are the same.]
[UPDATE: 7/27. The latest version of ASP2 has addressed the histogram and conversion -- it's now workable.]
Application vers.: 2.0.1.5
Product Name: AfterShot Pro 2 Registered
Built on: Wed May 28 2014
Platform: Linux
Language: en
App Path: /opt/AfterShotPro2(64-bit)/bin/AfterShotPro
System Home: /opt/AfterShotPro2(64-bit)/supportfiles
User Home: /home/jack/.AfterShotPro
Prefs Home: /home/jack/.config/Corel/AfterShot Pro.conf
Processors: 4
CPU Threads: 4
I/O Threads: 1
B. In-flight: 2
RAM: 7891 MB
SIMD Version: SSE2
Build Mode: Release
Issue: Ubuntu 13.10 \n \l
Kernel: Linux version 3.11.0-20-generic (buildd@panlong) (gcc version 4.8.1 (Ubuntu/Linaro 4.8.1-10ubuntu8) ) #35-Ubuntu SMP Fri May 2 21:32:49 UTC 2014
==================== Plugins =====================
Name:
Identifier:
Version: 1.0.0
Path:
Name: Black and White
Identifier: com.corel.BlackAndWhite
Version: 1.0.0
Path: <System Home>/plugins/Black and White.afplugin
Identifier: com.corel.equalizer
Version: 1.0.5
Path: <System Home>/plugins/Equalizer.afplugin
