No.afx wrote:And support never asked you to check the log????
cheers
afx
ASP2 no longer starts after crash
rgraf
- processor: Intel I7
Re: ASP2 no longer starts after crash
rgraf
Support was more astonished about my test scenario - applying some basic settings to the first image in one folder and then copy&paste these to the rest of the 1000 images in the folder. "This is not the way the product is intended to work" - Support said. Instead, doing this image by image would be the preferred way - thinks Corel.
afx
- System_Drive: N/A
- Video Card: FirePro 4900
Definitely clueless.rgraf wrote:Support was more astonished about my test scenario - applying some basic settings to the first image in one folder and then copy&paste these to the rest of the 1000 images in the folder. "This is not the way the product is intended to work" - Support said. Instead, doing this image by image would be the preferred way - thinks Corel.
Looks like they have no training at all.
Of course, this is one person, so I am not sure if this translates to the support staff in general, but it is scary.
cheers
afx
rgraf
Checked the AfterShotProlog with no findings, the files listed are theones which have been scanned - I assume.
To narrow it down, I created three folders with approx 1000 files each. One CR2 only, one ORF only and one JPG only.
Starting ASP2, selecting the JPG folder - everythings runs fine. Folder is scanned and previews get generated quickly.
Cache folder deleted.
Starting ASP2, selecting the CR2 folder - everythings runs fine. Folder is scanned and previews get generated quickly.
Starting ASP2, selecting the ORF folder - scan runs fine. After generating 162 from 922 previews, ASP2 crashed unmotivated.
Last test repeated.
Starting ASP2, selecting the ORF folder - everythings runs fine. Folder is scanned and previews get generated quickly.
It seems to be really strange as the behaviour is not replicable.
Thanks so far
rgr
Last test repeated.
Thanks so far
rgr
