How large is you Catalogs folder?
Kneops
- System_Drive: N/A
- motherboard: ASUS P8 Z68
- processor: Intel i7 2600
- Video Card: nVidia 450
- sound_card: onboard
- Hard_Drive_Capacity: 14 TB
- Monitor/Display Make & Model: Dell U2713H & Spider4
- Corel programs: ASP3
Because I'm trying to decide where to put my Aftershot Pro Catalog folder (which holds the catalogs, metadata and thumbs), how large has yours become and with how many images approximately? (in Gb or Tb).
Ludgateman
- motherboard: HP 1631
- processor: Intel Core i5 2540m
- Video Card: NVIDIA Quadro 1000m
- Hard_Drive_Capacity: 1TB
Re: How large is you Catalogs folder?
My current catalogue ans associated files (ASP1) for 17K Images is currently standing at 3.2GB. The whole lot ( catalogue, image files etc) are stored on a 1TB portable hard drive so I can run the same setup on my laptop or desktop machines. Runs very smoothly and fast via USB2 connections.
I've tried the same setup with ASP2 but have had so many problems with crashes that I've left it alone until the bugs are fixed.
Kneops
- System_Drive: N/A
Thanks, and a nice setup you have. Although I have a lot more images than 17K at the moment, I don't need to be afraid when I'm going to use the Catalog folder on a disk of 1Tb and the images on another disk.
You also made me think about disks and catalogs. I think I'm going to start with adding a main catelog with the name of the disk which contains subcatalogs with images. If that's full, I can add another disk an create a second main catalog
afx
- System_Drive: N/A
- Video Card: FirePro 4900
In contrast to many other apps, AS can have multiple catalogs open at the same time....
cheers
afx
cheers
afx
