Plugins don't work with ASP V2
AfterShot Pro Plugins
afx
operating_system: Linux
System_Drive: N/A
Video Card: FirePro 4900
Re: Plugins don't work with ASP V2
Post by afx »
Should be in /usr/bin: AfterShot2X64
cheers
afx
Coq
System_Drive: N/A
processor: Intel Core 2 Quad Q9550
ram: 5GB
Post by Coq »
Ok, basically :oops:
Code: Select all
$ AfterShot2X64
Install Path:           /opt/AfterShot2(64-bit)
LD_PATH:                /opt/AfterShot2(64-bit)/lib:
XLIB_SKIP_ARGB_VISUALS: 1
./AfterShotPro: /opt/AfterShot2(64-bit)/lib/libuuid.so.1: no version information available (required by /usr/lib/x86_64-linux-gnu/libSM.so.6)
	linux-vdso.so.1 =>  (0x00007fff805ce000)
	libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f96ef831000)
	libOpenCL.so.1 => /opt/AfterShot2(64-bit)/lib/libOpenCL.so.1 (0x00007f96ef62b000)
	libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007f96ef413000)
	libQtWebKit.so.4 => /opt/AfterShot2(64-bit)/lib/libQtWebKit.so.4 (0x00007f96edd9c000)
	libQtScript.so.4 => /opt/AfterShot2(64-bit)/lib/libQtScript.so.4 (0x00007f96ed8ed000)
	libQtSvg.so.4 => /opt/AfterShot2(64-bit)/lib/libQtSvg.so.4 (0x00007f96ed68f000)
	libQt3Support.so.4 => /opt/AfterShot2(64-bit)/lib/libQt3Support.so.4 (0x00007f96ed16f000)
	libQtSql.so.4 => /opt/AfterShot2(64-bit)/lib/libQtSql.so.4 (0x00007f96eceaf000)
	libQtNetwork.so.4 => /opt/AfterShot2(64-bit)/lib/libQtNetwork.so.4 (0x00007f96ecb66000)
	libQtDesigner.so.4 => /opt/AfterShot2(64-bit)/lib/libQtDesigner.so.4 (0x00007f96ec31c000)
	libQtXml.so.4 => /opt/AfterShot2(64-bit)/lib/libQtXml.so.4 (0x00007f96ec0d4000)
	libQtGui.so.4 => /opt/AfterShot2(64-bit)/lib/libQtGui.so.4 (0x00007f96eb3ab000)
	libQtCore.so.4 => /opt/AfterShot2(64-bit)/lib/libQtCore.so.4 (0x00007f96eaef2000)
	libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f96eacd6000)
	libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f96ea9ce000)
	libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f96ea74c000)
	libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f96ea536000)
	libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f96ea1a9000)
	/lib64/ld-linux-x86-64.so.2 (0x00007f96efa4c000)
	libXrender.so.1 => /usr/lib/x86_64-linux-gnu/libXrender.so.1 (0x00007f96e9fa0000)
	libfontconfig.so.1 => /usr/lib/x86_64-linux-gnu/libfontconfig.so.1 (0x00007f96e9d69000)
	libfreetype.so.6 => /usr/lib/x86_64-linux-gnu/libfreetype.so.6 (0x00007f96e9ac9000)
	libXext.so.6 => /usr/lib/x86_64-linux-gnu/libXext.so.6 (0x00007f96e98b7000)
	libX11.so.6 => /usr/lib/x86_64-linux-gnu/libX11.so.6 (0x00007f96e957c000)
	libgthread-2.0.so.0 => /usr/lib/x86_64-linux-gnu/libgthread-2.0.so.0 (0x00007f96e9379000)
	librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f96e9171000)
	libglib-2.0.so.0 => /lib/x86_64-linux-gnu/libglib-2.0.so.0 (0x00007f96e8e78000)
	libpng12.so.0 => /opt/AfterShot2(64-bit)/lib/libpng12.so.0 (0x00007f96e8c52000)
	libgobject-2.0.so.0 => /usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0 (0x00007f96e8a02000)
	libSM.so.6 => /usr/lib/x86_64-linux-gnu/libSM.so.6 (0x00007f96e87fa000)
	libICE.so.6 => /usr/lib/x86_64-linux-gnu/libICE.so.6 (0x00007f96e85df000)
	libexpat.so.1 => /lib/x86_64-linux-gnu/libexpat.so.1 (0x00007f96e83b4000)
	libxcb.so.1 => /usr/lib/x86_64-linux-gnu/libxcb.so.1 (0x00007f96e8194000)
	libpcre.so.3 => /lib/x86_64-linux-gnu/libpcre.so.3 (0x00007f96e7f56000)
	libffi.so.5 => /usr/lib/x86_64-linux-gnu/libffi.so.5 (0x00007f96e7d49000)
	libuuid.so.1 => /opt/AfterShot2(64-bit)/lib/libuuid.so.1 (0x000000309a000000)
	libXau.so.6 => /usr/lib/x86_64-linux-gnu/libXau.so.6 (0x00007f96e7b45000)
	libXdmcp.so.6 => /usr/lib/x86_64-linux-gnu/libXdmcp.so.6 (0x00007f96e7940000)
libuuid1 is installed (2.1.20.1-5.3) but it seems ASP can't find libuuid.
Code: Select all
# apt-cache policy libuuid*
libuuidm-ocaml-dev:
  Installé : (aucun)
  Candidat : 0.9.4-1
 Table de version :
     0.9.4-1 0
        500 http://ftp.fr.debian.org/debian/ wheezy/main amd64 Packages
     0.9.3-3+b1 0
        500 http://ftp.fr.debian.org/debian/ squeeze/main amd64 Packages
libuuid-tiny-perl:
  Installé : (aucun)
  Candidat : 1.0300-2
 Table de version :
     1.0300-2 0
     1.0300-1 0
libuuid-perl:
  Installé : 0.02-5
  Candidat : 0.02-5
 Table de version :
 *** 0.02-5 0
        100 /var/lib/dpkg/status
     0.02-4 0
libuuidm-ocaml-dev-se5v5:
  Installé : (aucun)
  Candidat : (aucun)
 Table de version :
libuuidtools-ruby-doc:
  Installé : (aucun)
  Candidat : 2.1.2-2
 Table de version :
     2.1.2-2 0
     2.1.1-2 0
libdata-uuid-libuuid-perl:
  Installé : (aucun)
  Candidat : 0.05-1+b2
 Table de version :
     0.05-1+b2 0
     0.05-1 0
libuuidtools-ruby1.8:
  Installé : (aucun)
  Candidat : 2.1.2-2
 Table de version :
     2.1.2-2 0
     2.1.1-2 0
libuuidtools-ruby1.9.1:
  Installé : (aucun)
  Candidat : 2.1.2-2
 Table de version :
     2.1.2-2 0
     2.1.1-2 0
libuuidtools-ruby:
  Installé : (aucun)
  Candidat : 2.1.2-2
 Table de version :
     2.1.2-2 0
     2.1.1-2 0
libuuidm-ocaml-dev-3teo8:
  Installé : (aucun)
  Candidat : (aucun)
 Table de version :
libuuid1:
  Installé : 2.20.1-5.3
  Candidat : 2.20.1-5.3
 Table de version :
 *** 2.20.1-5.3 0
     2.17.2-9 0
Debian 7 64 (stable) with xfce on Intel Q9550
afx
System_Drive: N/A
Post by afx »
If you use ldd on the wavelet sharpen lib do you see any errors there?
cheers
afx
Coq
System_Drive: N/A
ram: 5GB
Post by Coq »
Code: Select all
$ ldd lib/libWavelet.so
lib/libWavelet.so: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by lib/libWavelet.so)
lib/libWavelet.so: /lib/x86_64-linux-gnu/libm.so.6: version `GLIBC_2.15' not found (required by lib/libWavelet.so)
	linux-vdso.so.1 =>  (0x00007fffdc963000)
	libQtGui.so.4 => /usr/lib/x86_64-linux-gnu/libQtGui.so.4 (0x00007fba94929000)
	libQtCore.so.4 => /usr/lib/x86_64-linux-gnu/libQtCore.so.4 (0x00007fba94455000)
	libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007fba94238000)
	libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007fba93f31000)
	libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007fba93caf000)
	libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007fba93a98000)
	libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007fba9370c000)
	libfontconfig.so.1 => /usr/lib/x86_64-linux-gnu/libfontconfig.so.1 (0x00007fba934d5000)
	libaudio.so.2 => /usr/lib/x86_64-linux-gnu/libaudio.so.2 (0x00007fba932ba000)
	libglib-2.0.so.0 => /lib/x86_64-linux-gnu/libglib-2.0.so.0 (0x00007fba92fc2000)
	libpng12.so.0 => /lib/x86_64-linux-gnu/libpng12.so.0 (0x00007fba92d9b000)
	libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007fba92b83000)
	libfreetype.so.6 => /usr/lib/x86_64-linux-gnu/libfreetype.so.6 (0x00007fba928e4000)
	libgobject-2.0.so.0 => /usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0 (0x00007fba92694000)
	libSM.so.6 => /usr/lib/x86_64-linux-gnu/libSM.so.6 (0x00007fba9248c000)
	libICE.so.6 => /usr/lib/x86_64-linux-gnu/libICE.so.6 (0x00007fba92271000)
	libXrender.so.1 => /usr/lib/x86_64-linux-gnu/libXrender.so.1 (0x00007fba92068000)
	libXext.so.6 => /usr/lib/x86_64-linux-gnu/libXext.so.6 (0x00007fba91e55000)
	libX11.so.6 => /usr/lib/x86_64-linux-gnu/libX11.so.6 (0x00007fba91b1a000)
	libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007fba91916000)
	librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007fba9170d000)
	/lib64/ld-linux-x86-64.so.2 (0x00007fba95856000)
	libexpat.so.1 => /lib/x86_64-linux-gnu/libexpat.so.1 (0x00007fba914e3000)
	libXt.so.6 => /usr/lib/x86_64-linux-gnu/libXt.so.6 (0x00007fba9127b000)
	libXau.so.6 => /usr/lib/x86_64-linux-gnu/libXau.so.6 (0x00007fba91078000)
	libpcre.so.3 => /lib/x86_64-linux-gnu/libpcre.so.3 (0x00007fba90e3b000)
	libgthread-2.0.so.0 => /usr/lib/x86_64-linux-gnu/libgthread-2.0.so.0 (0x00007fba90c38000)
	libffi.so.5 => /usr/lib/x86_64-linux-gnu/libffi.so.5 (0x00007fba90a2b000)
	libuuid.so.1 => /lib/x86_64-linux-gnu/libuuid.so.1 (0x00007fba90826000)
	libxcb.so.1 => /usr/lib/x86_64-linux-gnu/libxcb.so.1 (0x00007fba90605000)
	libXdmcp.so.6 => /usr/lib/x86_64-linux-gnu/libXdmcp.so.6 (0x00007fba90400000)
Well… I have libc6 installed and can find neither libc nor glibc as a package. Same issue with libWaveletDenoise.so. No issue with Vigne:
Code: Select all
$ ldd libVigne.so
	linux-gate.so.1 =>  (0xf77b3000)
	libQtGui.so.4 => not found
	libQtCore.so.4 => not found
	libpthread.so.0 => /lib32/libpthread.so.0 (0xf7775000)
	libstdc++.so.6 => /usr/lib32/libstdc++.so.6 (0xf7689000)
	libm.so.6 => /lib32/libm.so.6 (0xf7663000)
	libgcc_s.so.1 => /usr/lib32/libgcc_s.so.1 (0xf7645000)
	libc.so.6 => /lib32/libc.so.6 (0xf74df000)
	/lib/ld-linux.so.2 (0xf77b4000)
afx
System_Drive: N/A
Post by afx »
$ ldd libWavelet.so |egrep "libc|libm"
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f2e1444e000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f2e13e71000)
$ dpkg -S /lib/x86_64-linux-gnu/libm.so.6
libc6:amd64: /lib/x86_64-linux-gnu/libm.so.6
$ dpkg -S /lib/x86_64-linux-gnu/libc.so.6
libc6:amd64: /lib/x86_64-linux-gnu/libc.so.6
So this all is about the libc / libm that was used by Dieter when he compiled the stuff (at least for the Wavelet plugins).
I'll contact him.
cheers
afx
Coq
System_Drive: N/A
ram: 5GB
Post by Coq »
trancept
System_Drive: N/A
motherboard: Gigabyte
processor: AMD Phenom X3 BE
ram: 4GB
Video Card: Nvidia GTX
sound_card: AMD chipset
Hard_Drive_Capacity: 1To
Monitor/Display Make & Model: ViewSonic 21"
Post by trancept »
Hello,
I was unable to run any plugin. I've done a fresh install of AfterShotPro 2.1.1.9 64bit on Ubuntu 64bit 14.04.1 LTS but I got the error :
Code: Select all
0.109: "Error loading plugin: /home/ben/.AfterShot/Plugins (64-bit)/zPerspector.afplugin"
0.109: "Plugin library contained no recognizable symbols."
Code: Select all
ben@Antec:/opt$ LD_LIBRARY_PATH=/opt/AfterShot2\(64-bit\)/lib ldd ~/.AfterShot/Plugins\ \(64-bit\)/zPerspector.afplugin/lib/libzPerspector.so
	linux-gate.so.1 =>  (0xf775b000)
	libpthread.so.0 => /lib/i386-linux-gnu/libpthread.so.0 (0xf7702000)
	libstdc++.so.6 => /usr/lib/i386-linux-gnu/libstdc++.so.6 (0xf7619000)
	libm.so.6 => /lib/i386-linux-gnu/libm.so.6 (0xf75d2000)
	libgcc_s.so.1 => /lib/i386-linux-gnu/libgcc_s.so.1 (0xf75b5000)
	libc.so.6 => /lib/i386-linux-gnu/libc.so.6 (0xf7406000)
	/lib/ld-linux.so.2 (0xf775c000)
ben@Antec:~$ find ~/.AfterShot/ -type f -name '*.so*' -ls -exec file '{}' \;[/code]
145473 96 -rw-rw-r-- 1 ben ben 88836 déc. 7 17:07 /home/ben/.AfterShot/Plugins\ (64-bit)/zPerspector.afplugin/lib/libzPerspector.so
/home/ben/.AfterShot/Plugins (64-bit)/zPerspector.afplugin/lib/libzPerspector.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
I look after 64 bit plugin on the website and dind't find anything... So I switch back to i386 version of AfterShot, re-install plugin and Yeah it works !
Any idea why there is no 64bit version of the PlugIn ? Does it mean developpers stop supporting AfterShot ?
I can see that there is some 64bit plugin in the forum, so why Corel doesn't update the website ?
Linux is 64bit since 2003 and we are in 2014...
spoilerhead
System_Drive: N/A
Hard_Drive_Capacity: 13.5TB
Post by spoilerhead »
trancept wrote:Any idea why there is no 64bit version of the PlugIn ? Does it mean developpers stop supporting AfterShot ?
The plugin page is a total mess. I currently don't even have a clue on how i can login and update my entries there.
Also, in my opinion the plugin format is messed up, because you can't include 32 and 64bit plugins in the same package, and the package itself doesn't specify if it contains 32 or 64 bit files.
my ASP Plugins - donation button ( send beer! :) )
linux,7d, glass and a huge mug of coffee.
If you got any immediate problems with my plugins, don't by shy on contact me on GoogleTalk.
trancept
System_Drive: N/A
ram: 4GB
Post by trancept »
Thank you for responding.
I finally re-install the 64bit version with plug-ins of the forum.
