Plugins don't work with ASP V2
AfterShot Pro Plugins
imhotep
operating_system: Linux
System_Drive: N/A
Post by imhotep »
Hi Folks,
I have an issue with the plugins. After I upgraded to Version 2 I can't install any plugins anymore.
Actually I can install them but they never appear.
Don't these plugins work with Version 2?
Or do I have to follow a secret procedure to install them?
Karsten
df
ram: 64gb
Hard_Drive_Capacity: 1 Tb
Re: Plugins don't work with ASP V2
Post by df »
If you're using the 64 bit version you'll need either 64 bit plug-ins or use the 32 bit version of ASP. Before anyone gets mad about that, just note that it's the same scenario with any plug-in to any program, not just Corel.
Regards, Dan
imhotep
System_Drive: N/A
Post by imhotep »
Thanks for the reply!
However, there is no hint on the plugin page (http://www.aftershotpro.com/de/plugins/) on any differences between 32 Bit and 64 Bit. Not even on the single plugin there is a hint whether in works in 64 Bit or not. I do have two plugins working in my 64 Bit Version. So how can I tell which one is 64 Bit enabled and which one is not, trial and error?
Karsten
Hobgoblin
System_Drive: N/A
Post by Hobgoblin »
imhotep wrote:Thanks for the reply!
Karsten
Simply really, aside from the two plugins installed with the program NONE of the Plugins are available for 64Bit at present.
Corel claim that they are coming ...
How long we may have to wait is another matter.
R.
Nico Koolsbergen
ram: 4 GB
Post by Nico Koolsbergen »
Yesterday I registered AfterShot Pro V2. I received a message that new users could download a surprise. The surprise was a plugin which doesn't work on my 64bits machine. Great present :( But I like the program!
PhilD41
processor: AMD FX-8120
ram: 16 GB
Post by PhilD41 »
Hummm... Hopefully sooner than later!!! I just upgraded, but I am not sure it is worth it without a few of the plug-ins I had come to depend on. I guess time will tell.
afx
System_Drive: N/A
Video Card: FirePro 4900
Post by afx »
Nico Koolsbergen wrote:Yesterday I registered AfterShot Pro V2. I received a message that new users could download a surprise. The surprise was a plugin which doesn't work on my 64bits machine. Great present :( But I like the program!
Install the 32bit version until the plugin mess is sorted out.
cheers
afx
Coq
System_Drive: N/A
processor: Intel Core 2 Quad Q9550
ram: 5GB
Post by Coq »
Hello there,
Same issue with me. I installed ASP 2 x64 on my GNU/Linux Debian (version 2.1.0.40 x64), it runs properly, then tried to install plugins either meant to be available for all platforms (Vigne) or compiled for x64 (Wavelet Denoise and Sharpen 2). None of them is available in ASP while a repository has been created for each plugin in my user folder, named ".AfterShotPro2/Plugins (64-bits)" in my case.
Has anyone managed to install and run plugins with ASP2 64 under Linux ?
Thanks in advance.
Debian 7 64 (stable) with xfce on Intel Q9550
afx
System_Drive: N/A
Post by afx »
They work just fine on my Ubuntu box.
Do you see any errors when you look in the log or start AS from the commandline?
cheers
afx
dFlyer
System_Drive: N/A
Post by dFlyer »
I have all the 64 bit plugins installed and working with Ubuntu 14.04-1.
Thanks.
Gary Garibaldi
Linux since 96
Sony a700
Sony a100
Coq
System_Drive: N/A
ram: 5GB
Post by Coq »
Sorry I didn't even thought about that. I've just tried launching ASP2 from the command line and I do get some errors :
Code: Select all
$ AfterShot2X64
Install Path:           /opt/AfterShot2(64-bit)
LD_PATH:                /opt/AfterShot2(64-bit)/lib:
XLIB_SKIP_ARGB_VISUALS: 1
./AfterShotPro: /opt/AfterShot2(64-bit)/lib/libuuid.so.1: no version information available (required by /usr/lib/x86_64-linux-gnu/libSM.so.6)
0.0: QGtkStyle was unable to detect the current GTK+ theme.
0.2: I have SSE2
0.6: Bibble program arguments ("./AfterShotPro")
0.6: Loaded  "/opt/AfterShot2(64-bit)/supportfiles/locale/aftershot_fr.qm"
0.6: Loaded  "/opt/AfterShot2(64-bit)/supportfiles/locale/qt_fr.qm"
0.6: Loading plugins
0.7: "Error loading plugin: /home/coq/.AfterShotPro2/Plugins (64-bit)/Vigne.afplugin"
0.7: "Plugin library contained no recognizable symbols."
0.7:
0.9: "Error loading plugin: /home/coq/.AfterShotPro2/Plugins (64-bit)/Wavelet Denoise.afplugin"
0.9: "Plugin library contained no recognizable symbols."
0.9:
0.10: "Error loading plugin: /home/coq/.AfterShotPro2/Plugins (64-bit)/WaveletSharpen2.afplugin"
0.10: "Plugin library contained no recognizable symbols."
0.10:
0.13: "Error initializing plugin: /opt/AfterShot2(64-bit)/supportfiles/plugins/Nostalgia.afplugin"
0.13: "Plugin did not validate:
	Library file missing: lib/Nostalgia.dll
0.13:
Well, that does not help me to guess what's wrong… :? I guess the issue does not come from all plugins.
afx
System_Drive: N/A
Post by afx »
If you run nm on the libWavelet.so file in WaveletSharpen2.afplugin, what do you get?
cheers
afx
Coq
System_Drive: N/A
ram: 5GB
Post by Coq »
Here is the result:
Code: Select all
$ nm libWavelet.so
000000000025e2b0 d DW.ref._ZTISt9bad_alloc
000000000025e2b8 d DW.ref.__gxx_personality_v0
000000000025dd00 d _DYNAMIC
000000000025e000 d _GLOBAL_OFFSET_TABLE_
0000000000006f80 t _GLOBAL__sub_I_FilterLLorens.cpp
0000000000006f40 t _GLOBAL__sub_I_FilterSharpen.cpp
0000000000006fc0 t _GLOBAL__sub_I_FilterUSM.cpp
0000000000006ec0 t _GLOBAL__sub_I_SharpenPlugin.cpp
0000000000006f00 t _GLOBAL__sub_I_sphLayerFilter.cpp
                 w _ITM_deregisterTMCloneTable
                 w _ITM_registerTMCloneTable
                 w _Jv_RegisterClasses
                 U _Unwind_Resume@@GCC_3.0
00000000000128c0 T _Z10convolve1DPfS_iS_i
0000000000013480 T _Z10convolve2DPdS_iiS_ii
0000000000013280 T _Z10convolve2DPfS_iiS_ii
0000000000012be0 T _Z10convolve2DPhS_iiPfii
0000000000013060 T _Z10convolve2DPiS_iiPfii
0000000000012e00 T _Z10convolve2DPtS_iiPfii
0000000000011b40 T _Z13microcontrastPfjjf
0000000000010f00 T _Z14LlorensSharpenPfjjif
0000000000015a80 T _Z14convolve2DFastPhS_iiPfii
00000000000129e0 T _Z14convolve2DSlowPhS_iiPfii
0000000000012740 T _Z15USM_IIR_stackedPfjjff
00000000000166a0 T _Z15convolve2DFast2PhS_iiPifii
0000000000010400 T _Z16wavelet_sharpenFPPfjjff
                 U _Z17qt_message_output9QtMsgTypePKc
0000000000015380 T _Z19convolve2DSeparablePdS_iiS_iPfi
0000000000014ca0 T _Z19convolve2DSeparablePfS_iiPKfiS1_i
00000000000136a0 T _Z19convolve2DSeparablePhS_iiPfiS0_i
0000000000014580 T _Z19convolve2DSeparablePiS_iiPfiS0_i
0000000000013e00 T _Z19convolve2DSeparablePtS_iiPfiS0_i
                 U _Z5qFreePv
0000000000012680 T _Z7USM_IIRPfjjf
0000000000010ac0 T _Z9dePepperFPPfjj
0000000000012440 t _ZL10iir_filterP9iir_paramPfii
000000000000fbc0 t _ZL12edgeFunctionf
00000000000597a0 r _ZL12sigmoidtable
000000000005a240 r _ZL26qt_meta_data_SharpenPlugin
000000000005a100 r _ZL32qt_meta_stringdata_SharpenPlugin
0000000000019660 r _ZL7sqrtLUT
0000000000012560 t _ZL8iir_initP9iir_paramf
                 U _ZN10QByteArray7reallocEi
000000000000ba00 W _ZN10QByteArrayD1Ev
000000000000ba00 W _ZN10QByteArrayD2Ev
                 U _ZN11QTextStreamC1EP7QString6QFlagsIN9QIODevice12OpenModeFlagEE
                 U _ZN11QTextStreamD1Ev
                 U _ZN11QTextStreamlsEPKv
                 U _ZN11QTextStreamlsERK7QString
                 U _ZN11QTextStreamlsEc
                 U _ZN11QTextStreamlsEi
0000000000017f60 W _ZN12PluginData_0D0Ev
0000000000017f20 W _ZN12PluginData_0D1Ev
0000000000017f20 W _ZN12PluginData_0D2Ev
0000000000010cc0 T _ZN13LLorensFilter18needsOriginalImageEv
0000000000010ec0 W _ZN13LLorensFilterD0Ev
0000000000010ea0 W _ZN13LLorensFilterD1Ev
0000000000010ea0 W _ZN13LLorensFilterD2Ev
0000000000018a40 T _ZN13SharpenPlugin11qt_metacallEN11QMetaObject4CallEiPPv
00000000000189e0 T _ZN13SharpenPlugin11qt_metacastEPKc
0000000000007140 T _ZN13SharpenPlugin11toolWidgetsEv
000000000000a0e0 T _ZN13SharpenPlugin15registerFiltersEv
0000000000007260 T _ZN13SharpenPlugin15registerOptionsEv
0000000000009700 T _ZN13SharpenPlugin16createDependencyERK7QString
000000000025dce0 D _ZN13SharpenPlugin16staticMetaObjectE
0000000000007180 T _ZN13SharpenPlugin17toolWidgetCreatedEP7QWidget
0000000000008fc0 T _ZN13SharpenPlugin19handleControlChangeERK7QStringiiRK21PluginImageSettings_0RK18PluginOptionList_0RS6_
0000000000009220 T _ZN13SharpenPlugin20handleHotnessChangedERK21PluginImageSettings_0
0000000000008fa0 T _ZN13SharpenPlugin20handleSettingsChangeERK21PluginImageSettings_0S2_i
0000000000009240 T _ZN13SharpenPlugin4initEP11PluginHub_0iiRK7QString
0000000000018b60 W _ZN13SharpenPlugin4nameEv
0000000000018ba0 W _ZN13SharpenPlugin5groupEv
00000000000071c0 T _ZN13SharpenPlugin6finishEv
0000000000018b20 W _ZN13SharpenPlugin8priorityEv
0000000000007100 T _ZN13SharpenPlugin9toolFilesEv
0000000000018c40 W _ZN13SharpenPluginD0Ev
0000000000018be0 W _ZN13SharpenPluginD1Ev
0000000000018be0 W _ZN13SharpenPluginD2Ev
000000000000ee60 W _ZN13sphPixelCache8getPixelEii
000000000000e9a0 W _ZN14sphLayerFilterD0Ev
000000000000e980 W _ZN14sphLayerFilterD1Ev
000000000000e980 W _ZN14sphLayerFilterD2Ev
0000000000017f40 W _ZN16PluginDependencyD0Ev
0000000000017f00 W _ZN16PluginDependencyD1Ev
0000000000017f00 W _ZN16PluginDependencyD2Ev
000000000000b9e0 W _ZN19PluginLayerFilter_0D0Ev
000000000000b9a0 W _ZN19PluginLayerFilter_0D1Ev
000000000000b9a0 W _ZN19PluginLayerFilter_0D2Ev
000000000000fac0 T _ZN20WaveletSharpenFilter18needsOriginalImageEv
00000000000103c0 W _ZN20WaveletSharpenFilterD0Ev
00000000000103a0 W _ZN20WaveletSharpenFilterD1Ev
00000000000103a0 W _ZN20WaveletSharpenFilterD2Ev
0000000000018880 W _ZN5QListI6OptionE13detach_helperEi
0000000000018260 W _ZN5QListI6OptionE18detach_helper_growEii
00000000000173c0 t _ZN5QListI6OptionE4freeEPN9QListData4DataE.isra.6
00000000000185a0 W _ZN5QListI6OptionE6appendERKS0_
0000000000017fe0 W _ZN5QListI6OptionED1Ev
0000000000017fe0 W _ZN5QListI6OptionED2Ev
000000000000ed40 W _ZN5QListI6TCDataE13detach_helperEi
000000000000ea00 W _ZN5QListI6TCDataE18detach_helper_growEii
000000000000bb80 t _ZN5QListI6TCDataE4freeEPN9QListData4DataE.isra.11
000000000000ec80 W _ZN5QListI6TCDataE6appendERKS0_
000000000000e9c0 W _ZN5QListI6TCDataED1Ev
000000000000e9c0 W _ZN5QListI6TCDataED2Ev
0000000000018800 W _ZN5QListIiE13detach_helperEi
0000000000018680 W _ZN5QListIiE18detach_helper_growEii
0000000000018780 W _ZN5QListIiE6appendERKi
0000000000017fa0 W _ZN5QListIiED1Ev
0000000000017fa0 W _ZN5QListIiED2Ev
00000000000181c0 W _ZN6OptionD1Ev
00000000000181c0 W _ZN6OptionD2Ev
000000000000ba40 W _ZN6QDebugD1Ev
000000000000ba40 W _ZN6QDebugD2Ev
                 U _ZN7QObject10childEventEP11QChildEvent
                 U _ZN7QObject10timerEventEP11QTimerEvent
                 U _ZN7QObject11customEventEP6QEvent
                 U _ZN7QObject11eventFilterEPS_P6QEvent
                 U _ZN7QObject11qt_metacallEN11QMetaObject4CallEiPPv
                 U _ZN7QObject11qt_metacastEPKc
                 U _ZN7QObject13connectNotifyEPKc
                 U _ZN7QObject16disconnectNotifyEPKc
                 U _ZN7QObject16staticMetaObjectE
                 U _ZN7QObject5eventEP6QEvent
                 U _ZN7QObject7connectEPKS_PKcS1_S3_N2Qt14ConnectionTypeE
                 U _ZN7QObjectC2EPS_
                 U _ZN7QObjectD2Ev
                 U _ZN7QString11shared_nullE
                 U _ZN7QString16codecForCStringsE
                 U _ZN7QString16fromAscii_helperEPKci
                 U _ZN7QString4freeEPNS_4DataE
                 U _ZN7QString9fromAsciiEPKci
000000000000ba20 W _ZN7QStringD1Ev
000000000000ba20 W _ZN7QStringD2Ev
                 U _ZN7QStringaSERKS_
000000000000b980 W _ZN8Plugin_07versionEv
000000000000b9c0 W _ZN8Plugin_0D0Ev
000000000000b960 W _ZN8Plugin_0D1Ev
000000000000b960 W _ZN8Plugin_0D2Ev
                 U _ZN8QVariantC1Ei
                 U _ZN8QVariantD1Ev
0000000000017580 T _ZN8ToolData12addEnabledIdEi7QStringS0_S0_
0000000000017b40 T _ZN8ToolData3runERK21PluginImageSettings_0RK20PluginPipeSettings_0
0000000000017760 T _ZN8ToolDataC1ERKS_
00000000000174c0 T _ZN8ToolDataC1Ev
0000000000017760 T _ZN8ToolDataC2ERKS_
00000000000174c0 T _ZN8ToolDataC2Ev
00000000000180e0 W _ZN8ToolDataD0Ev
0000000000018020 W _ZN8ToolDataD1Ev
0000000000018020 W _ZN8ToolDataD2Ev
                 U _ZN9QListData11detach_growEPii
                 U _ZN9QListData11shared_nullE
                 U _ZN9QListData5eraseEPPv
                 U _ZN9QListData6appendEv
                 U _ZN9QListData6detachEi
                 U _ZN9QListData7prependEv
                 U _ZN9QSettings8setValueERK7QStringRK8QVariant
                 U _ZN9QSettingsC1ERK7QStringS2_P7QObject
                 U _ZN9QSettingsD1Ev
0000000000012060 T _ZN9USMFilter18needsOriginalImageEv
0000000000012400 W _ZN9USMFilterD0Ev
00000000000123e0 W _ZN9USMFilterD1Ev
00000000000123e0 W _ZN9USMFilterD2Ev
                 U _ZNK11QMetaObject2trEPKcS1_
0000000000010d00 T _ZNK13LLorensFilter13ProcessBufferEPPfiifRK21PluginImageSettings_0RK20PluginPipeSettings_0R12PluginTile_0R18PluginOptionList_0i
0000000000010c60 T _ZNK13LLorensFilter15needsToRunLayerERK21PluginImageSettings_0RK20PluginPipeSettings_0R18PluginOptionList_0
0000000000010ce0 T _ZNK13LLorensFilter16additionalRadiusEP18PluginOptionList_0f
0000000000010ee0 W _ZNK13LLorensFilter4nameEv
0000000000010ca0 T _ZNK13LLorensFilter6isSlowERK21PluginImageSettings_0RK20PluginPipeSettings_0
00000000000189c0 T _ZNK13SharpenPlugin10metaObjectEv
000000000000bbe0 T _ZNK14sphLayerFilter13getBufferRectEP18PluginOptionList_0RK20PluginPipeSettings_0R12PluginTile_0
000000000000bb60 T _ZNK14sphLayerFilter13isLargeRadiusERK21PluginImageSettings_0RK20PluginPipeSettings_0
000000000000c500 T _ZNK14sphLayerFilter13prerequisitesERK21PluginImageSettings_0RK20PluginPipeSettings_0R12PluginTile_0
000000000000bca0 T _ZNK14sphLayerFilter19getPrerequisiteRectEP18PluginOptionList_0RK20PluginPipeSettings_0R12PluginTile_0
000000000000c620 T _ZNK14sphLayerFilter8runLayerERK21PluginImageSettings_0RK20PluginPipeSettings_0R12PluginTile_0R18PluginOptionList_0i
000000000000fc60 T _ZNK20WaveletSharpenFilter13ProcessBufferEPPfiifRK21PluginImageSettings_0RK20PluginPipeSettings_0R12PluginTile_0R18PluginOptionList_0i
000000000000fa40 T _ZNK20WaveletSharpenFilter15needsToRunLayerERK21PluginImageSettings_0RK20PluginPipeSettings_0R18PluginOptionList_0
000000000000fae0 T _ZNK20WaveletSharpenFilter16additionalRadiusEP18PluginOptionList_0f
00000000000103e0 W _ZNK20WaveletSharpenFilter4nameEv
000000000000faa0 T _ZNK20WaveletSharpenFilter6isSlowERK21PluginImageSettings_0RK20PluginPipeSettings_0
                 U _ZNK5QRectanERKS_
                 U _ZNK5QRectorERKS_
                 U _ZNK7QString11toLocal8BitEv
                 U _ZNK7QStringeqERK13QLatin1String
                 U _ZNK7QStringeqERKS_
0000000000017f80 W _ZNK8ToolData10filterNameEv
00000000000173a0 T _ZNK8ToolData12requiresDiskEv
0000000000017380 T _ZNK8ToolData13prerequisitesERK21PluginImageSettings_0RK20PluginPipeSettings_0
0000000000012120 T _ZNK9USMFilter13ProcessBufferEPPfiifRK21PluginImageSettings_0RK20PluginPipeSettings_0R12PluginTile_0R18PluginOptionList_0i
0000000000012000 T _ZNK9USMFilter15needsToRunLayerERK21PluginImageSettings_0RK20PluginPipeSettings_0R18PluginOptionList_0
0000000000012080 T _ZNK9USMFilter16additionalRadiusEP18PluginOptionList_0f
0000000000012420 W _ZNK9USMFilter4nameEv
0000000000012040 T _ZNK9USMFilter6isSlowERK21PluginImageSettings_0RK20PluginPipeSettings_0
                 U _ZNSt8ios_base4InitC1Ev@@GLIBCXX_3.4
                 U _ZNSt8ios_base4InitD1Ev@@GLIBCXX_3.4
000000000025e2c4 b _ZStL8__ioinit
000000000025e2c8 b _ZStL8__ioinit
000000000025e2cc b _ZStL8__ioinit
000000000025e2d0 b _ZStL8__ioinit
000000000025e2d4 b _ZStL8__ioinit
000000000025da50 V _ZTI12PluginData_0
000000000025d7d0 V _ZTI12PluginTile_0
000000000025d910 V _ZTI13LLorensFilter
000000000025db40 V _ZTI13SharpenPlugin
000000000025d7a0 V _ZTI14sphLayerFilter
000000000025d7c0 V _ZTI16PluginDependency
000000000025d6b0 V _ZTI19PluginLayerFilter_0
000000000025d870 V _ZTI20WaveletSharpenFilter
                 U _ZTI7QObject
000000000025d6a0 V _ZTI8Plugin_0
000000000025da70 V _ZTI8ToolData
000000000025d9b0 V _ZTI9USMFilter
                 U _ZTISt9bad_alloc@@GLIBCXX_3.4
000000000005a0af V _ZTS12PluginData_0
0000000000059693 V _ZTS12PluginTile_0
000000000005a000 V _ZTS13LLorensFilter
000000000005a2c0 V _ZTS13SharpenPlugin
0000000000059660 V _ZTS14sphLayerFilter
0000000000059680 V _ZTS16PluginDependency
0000000000019470 V _ZTS19PluginLayerFilter_0
0000000000059fb0 V _ZTS20WaveletSharpenFilter
0000000000019460 V _ZTS8Plugin_0
000000000005a0be V _ZTS8ToolData
000000000005a038 V _ZTS9USMFilter
000000000025dac0 V _ZTV12PluginData_0
000000000025d940 V _ZTV13LLorensFilter
000000000025db80 V _ZTV13SharpenPlugin
000000000025d800 V _ZTV14sphLayerFilter
000000000025daa0 V _ZTV16PluginDependency
000000000025d740 V _ZTV19PluginLayerFilter_0
000000000025d8a0 V _ZTV20WaveletSharpenFilter
000000000025d6c0 V _ZTV8Plugin_0
000000000025db00 V _ZTV8ToolData
000000000025d9e0 V _ZTV9USMFilter
                 U _ZTVN10__cxxabiv117__class_type_infoE@@CXXABI_1.3
                 U _ZTVN10__cxxabiv120__si_class_type_infoE@@CXXABI_1.3
                 U _ZTVN10__cxxabiv121__vmi_class_type_infoE@@CXXABI_1.3
0000000000007160 T _ZThn16_N13SharpenPlugin11toolWidgetsEv
000000000000b940 T _ZThn16_N13SharpenPlugin15registerFiltersEv
0000000000008f20 T _ZThn16_N13SharpenPlugin15registerOptionsEv
000000000000a0c0 T _ZThn16_N13SharpenPlugin16createDependencyERK7QString
00000000000071a0 T _ZThn16_N13SharpenPlugin17toolWidgetCreatedEP7QWidget
00000000000096e0 T _ZThn16_N13SharpenPlugin4initEP11PluginHub_0iiRK7QString
0000000000018b80 W _ZThn16_N13SharpenPlugin4nameEv
0000000000018bc0 W _ZThn16_N13SharpenPlugin5groupEv
0000000000007240 T _ZThn16_N13SharpenPlugin6finishEv
0000000000018b40 W _ZThn16_N13SharpenPlugin8priorityEv
0000000000007120 T _ZThn16_N13SharpenPlugin9toolFilesEv
0000000000018c80 W _ZThn16_N13SharpenPluginD0Ev
0000000000018c20 W _ZThn16_N13SharpenPluginD1Ev
                 U _ZdaPv@@GLIBCXX_3.4
                 U _ZdlPv@@GLIBCXX_3.4
                 U _Zls6QDebugRK5QSize
                 U _Znam@@GLIBCXX_3.4
                 U _Znwm@@GLIBCXX_3.4
000000000005bfa8 r __FRAME_END__
000000000025d698 d __JCR_END__
000000000025d698 d __JCR_LIST__
000000000025e2c0 d __TMC_END__
000000000025e2c0 B __bss_start
                 U __cxa_atexit@@GLIBC_2.2.5
                 U __cxa_begin_catch@@CXXABI_1.3
                 U __cxa_end_catch@@CXXABI_1.3
                 w __cxa_finalize@@GLIBC_2.2.5
                 U __cxa_pure_virtual@@CXXABI_1.3
                 U __cxa_rethrow@@CXXABI_1.3
0000000000007080 t __do_global_dtors_aux
000000000025d690 t __do_global_dtors_aux_fini_array_entry
000000000025e2a8 d __dso_handle
                 U __dynamic_cast@@CXXABI_1.3
                 U __expf_finite@@GLIBC_2.15
000000000025d658 t __frame_dummy_init_array_entry
                 w __gmon_start__
                 U __gxx_personality_v0@@CXXABI_1.3
                 U __powisf2@@GCC_4.0.0
000000000025e2c0 D _edata
000000000025e2d8 B _end
0000000000018c88 T _fini
0000000000006958 T _init
0000000000008f40 T b5plugin
000000000025e2c0 b completed.6362
0000000000007010 t deregister_tm_clones
00000000000070c0 t frame_dummy
                 U memcpy@@GLIBC_2.14
0000000000007040 t register_tm_clones
0000000000006ff0 t set_fast_math
Thanks.
afx
System_Drive: N/A
Post by afx »
Ok, that looks fine.
So why has AS on your box issues with loading the plugins?
What is the difference?
Is there something missing on plain Debian that exists on Ubuntu which is needed?
I am thinking of some shared lib, but at the moment I don't know how to identify it.
There is a commented ldd line in the startup script right before the actual program start. You could activate that and see if there are any complaints at startup.
cheers
afx
Coq
System_Drive: N/A
ram: 5GB
Post by Coq »
I deactivated the install of suggested packages from the start on my Debian, so that may be possible.
Where can I find the startup script you mention?
