hello,
May i ask you if i can have screen recording and the file to be other format than .wmv? I am asking because if i have 3-4 hours of screenrecording the result is a file about 2-3 gb and when i tried to import it in timeline a message appeared : this file isnt editable .....e.t.c.
Thank you in advance
Takis
screen capture in other format than .wmv?
Re: screen capture in other format than .wmv?
Unfortunately there is no other option for screen capture than .wmv
but you should be able to put that screen capture back into the timeline for editing - all of the free video samples provided with VideoStudio are .wmv files - can you import all of those without problem or do they give an error as well ?
Does your screen capture file play in Windows Media player ?
What is the complete error message you receive ?
vakata
- motherboard: GIGABYTE-GA-EX58-UD4P
- processor: INTEL i7-920
- ram: 12GB
- Video Card: ATI 4890
- Hard_Drive_Capacity: 320
- Monitor/Display Make & Model: SAMSUNG SUNCMASTER T240HD (1920X1200)
hi Brian,
Thank you for your reply. When i tried to insert the .wmv file-which is the file after the end of my screen recording about 3 gb) in timeline appeared a message (attached message.1) and after i click on ''ok'' appeared a bar with ''pre-process status'' i guess tried to mkake the file editable or whatever
. But he never complete this process and appeared a message (attached message.2)
I look forward for your answer.
Regards
Takis
Regards
Takis
can you play the sample .wmv videos supplied with VideoStudio
can you make a short screen capture - say about 5 minutes - can you play that video
