I have several different projects that I want to combine into just one project and burn to a DVD. Is there a way to add another project to the one that is currently open? Thank you.
Found it. The option is available after you go to the creat disk menu.
Adding additional projects in VS9
jchunter
Skiman,
Don't use the control to "Add Project" because it will result in a lengthy re-rendering of compliant videos that often ends up in a crash. Follow the procedure that is described in to top sticky post: Make video files of each separate project and combine them using the "Add Video" control when you are ready to burn your DVD.
John
John
