Corel videostudio pro X2 + Konig grabber
jcamper
Post by jcamper »
Hi all, has anyone got any idea how to solve the problem of non capture using the Konig video grabber usb device with prox2 the Em2828x driver is installed and captures with its own software and windows 64bit did Maker? It says the plugin is in Use? Any help welcome.
Thanks in advance.
Re: Corel videostudio pro X2 + Konig grabber
Post by BrianCee »
If you can capture with the supplied software then that is what you should do - some capture devices are 'tweaked' to work only with the manufacturers software.
So the best solution to your problem is to use what was supplied and simply import/insert to VideoStudio
jcamper
Post by jcamper »
BrianCee wrote:If you can capture with the supplied software then that is what you should do - some capture devices are 'tweaked' to work only with the manufacturers software.
ok thanks.
Jcamper
