A few question about VS9
Merlin the Wizard
Post by Merlin the Wizard »
Hello,
In VS9, I uses the Quick Scan functiont o break out the contents of the DV tape into segments base on the time code. I have 4 questions:
- Is there any way to improve the accuracy of the "splits". I find that a small part of the last segments tends to appear in the this segment. Since the frames are time coded, it should be possible to identify the frame as belonging to which segment accurately right?
- Is there a way to customize the naming of the segment? I have no problem the way it name the segment by the time codes but I would prefer it if the naming also includes the date and time of the video taken, that is assuming that these information is available from the i1394 connection I am using.
- Is there anyway I can customize the "layout" of the listed titles/buttons when producing a DVD? It would be nice if the buttons can be moved.
- After producing a DVD, I find that there is no way to navigate the DVD titles using the next and previous button while playing. i.e. jump to the next or previous title. They seems to only work for chapters. Is there a way around this?
Thanks for any answer provided.
