I wanted to try ASP 2 on my machine (Slackware 14.1, 32-bit) but I get segfault early on when running it:
1) Using version 2.0.0.133
2) "Choose Folder Locations" dialogue, click "OK"
3) "AfterShotPro Trial", click "Try Corel AfterShot Pro"
4) Terminal reports "Segmentation fault"
It's reproducable, so I ensured all my settings were clean before future tests:
$ rm -Rf $HOME/.AfterShotPro $ rm -f "$HOME/.config/Corel/AfterShot Pro.conf"If I use gdb, I reliably get the following stack trace (and you can see the console log messages prior to the crash)
[...] 2.245: /home/mark/.AfterShotPro/bibbledebug 2.274: Creating main window 2.301: Starting Catalog Manager Program received signal SIGSEGV, Segmentation fault. 0x080af12e in sqlite3_busy_handler () (gdb) bt #0 0x080af12e in sqlite3_busy_handler () #1 0x089dc7a3 in DbManager::setupConnection(QSqlDatabase&) () #2 0x089dd750 in Database::Database(BString) () #3 0x089dfa48 in SimpleDbConnection::open(BString) () #4 0x089e6103 in DbManager::init() () #5 0x089e8859 in DbManager::instance() () #6 0x08b08b60 in ourmain(int, char**) () #7 0x08b0a822 in main ()After the crash, some files are created, but the 'bibbledebug' file mentioned above is not one of them. I can post the "AfterShotPro.log" file content if necessary, but it just ends with the 3 print lines above. Of the other files, one of them is zero in size:
$ ls -l $HOME/.AfterShotPro/rootdb -rw-r--r-- 1 mark users 0 Jun 6 18:59 /home/mark/.AfterShotPro/rootdband this chimes with the last few bits of activity if I run ASP through an 'strace':
stat64("/home/mark/.AfterShotPro/rootdb", {st_mode=S_IFREG|0644, st_size=0, ...}) = 0
open("/home/mark/.AfterShotPro/rootdb", O_RDWR|O_CREAT|O_LARGEFILE|O_CLOEXEC, 0644) = 10
fstat64(10, {st_mode=S_IFREG|0644, st_size=0, ...}) = 0
_llseek(10, 0, [0], SEEK_SET) = 0
read(10, "", 100) = 0
--- SIGSEGV {si_signo=SIGSEGV, si_code=SEGV_MAPERR, si_addr=0x37} ---
+++ killed by SIGSEGV (core dumped) +++
Segmentation fault
All libraries etc. are present according to ldd, so it seems I have the right versions of all required libraries and definitely not a basic compatibility problem. I also tried removing ASP's own lib/ files and using the system ones instead, with the same results in the tests above.I looked to see if anyone on the forum had anything similar, and the above seems to suggest its a bug that should be reported. I'd at least expect a sane message if I'm doing something wrong or if I don't have the required hardware/paths/permissions. I'm interested if anyone else gets this or has a reasonable workaround, and I hope the information above might be useful to developers.
Looking forward to being able to try ASP 2 soon.
Mark
