RPM installation
valdemarb
operating_system: Linux
RPM installation
Post by valdemarb »
Hello,
ASP 1.2.0.7 works well for me under Mageia OS. Now I wish to upgrade. The 32bit version of 2.0 is very slow and therefore useless - and the 64bit version will not start. I get the following error:
Code: Select all
[valdemar@localhost bin]$ ‎./AfterShotPro2X64
Install Path:           /opt/AfterShotPro2(64-bit)
LD_PATH:                /opt/AfterShotPro2(64-bit)/lib:
XLIB_SKIP_ARGB_VISUALS: 1
./AfterShotPro: /opt/AfterShotPro2(64-bit)/lib/libuuid.so.1: no version information available (required by /lib64/libSM.so.6)
Segmentation fault
Seems like ASP is using some old version of libuuid that does not show version info.
Is there somebody that can help me out?
Best regards,
Valdemar
afx
System_Drive: N/A
Video Card: FirePro 4900
Re: RPM installation
Post by afx »
libuuid is not the issue.
I get the same error, but AS continues:
Code: Select all
AfterShotPro2X64
./AfterShotPro: /opt/AfterShotPro2(64-bit)/lib/libuuid.so.1: no version information available (required by /usr/lib/x86_64-linux-gnu/libSM.so.6)
0.0: I have SSE2
0.4: Bibble program arguments ("./AfterShotPro")
0.4: Loading plugins
... and so on ...
Why is 32bit slow? Are you using OpenCL?
cheers
afx
valdemarb
Post by valdemarb »
Thanks afx for responding. That unfortunately leaves me with no clue, what is the culprit :( Guess I will have to switch OS to continue with AS.
I have no idea why the 32bit version of 2.0 is running slow. The graphics card is Intel HD Graphics 4000 and it does have OpenCL support.
Thanks,
Valdemar
valdemarb
Post by valdemarb »
afx, you got me started on this OpenCL thing. Unfortunately Intel provides no support for Linux, according to this thread https://software.intel.com/en-us/forums/topic/402118.
Without OpenCL AS 1.2.0.7 32bit is for me still way faster than the new 2.0 32bit.
Thanks,
Valdemar
afx
System_Drive: N/A
Post by afx »
Hmm, one thing I noticed on my W7 box is that Wavelet sharpen seems to be even slower on AS2 than on AS1. So check plugins.
And grab the update that was released yesterday.
cheers
afx
valdemarb
Post by valdemarb »
The patch cannot install on my distribution.
Code: Select all
[root@localhost Downloads]# rpm -ivh ASP2_LinuxRPM32_Patch01.rpm
Preparing...                          ################################# [100%]
	package AfterShotPro-174:2.0-0.0.i386 is already installed
	file /opt/AfterShotPro2/bin/AfterShotPro from install of AfterShotPro-174:2.0-0.0.i386 conflicts with file from package AfterShotPro-174:2.0-0.0.i386
	file /opt/AfterShotPro2/supportfiles/Profiles/LensProfiles/profile_micro43.txt from install of AfterShotPro-174:2.0-0.0.i386 conflicts with file from package AfterShotPro-174:2.0-0.0.i386
	file /opt/AfterShotPro2/supportfiles/Profiles/LensProfiles/profile_olympuslenstable.txt from install of AfterShotPro-174:2.0-0.0.i386 conflicts with file from package AfterShotPro-174:2.0-0.0.i386
	file /opt/AfterShotPro2/supportfiles/locale/aftershot_de.qm from install of AfterShotPro-174:2.0-0.0.i386 conflicts with file from package AfterShotPro-174:2.0-0.0.i386
	file /opt/AfterShotPro2/supportfiles/locale/aftershot_fr.qm from install of AfterShotPro-174:2.0-0.0.i386 conflicts with file from package AfterShotPro-174:2.0-0.0.i386
	file /opt/AfterShotPro2/supportfiles/locale/aftershot_it.qm from install of AfterShotPro-174:2.0-0.0.i386 conflicts with file from package AfterShotPro-174:2.0-0.0.i386
	file /opt/AfterShotPro2/supportfiles/locale/aftershot_ja.qm from install of AfterShotPro-174:2.0-0.0.i386 conflicts with file from package AfterShotPro-174:2.0-0.0.i386
	file /opt/AfterShotPro2/supportfiles/locale/aftershot_nl.qm from install of AfterShotPro-174:2.0-0.0.i386 conflicts with file from package AfterShotPro-174:2.0-0.0.i386
	file /opt/AfterShotPro2/supportfiles/tools/PerfectlyClearNoise.ui from install of AfterShotPro-174:2.0-0.0.i386 conflicts with file from package AfterShotPro-174:2.0-0.0.i386
Thanks,
Valdemar
afx
System_Drive: N/A
Post by afx »
Force it.
I really do not understand why the have problems setting up RPMs properly....
cheers
afx
valdemarb
Post by valdemarb »
Ok, I forced it and the patch then overwrote the old AS. Now 2.0.1.5 crashes all the time. Just scrolling thumbnails will make AS terminate.
I give up on AS, but thanks afx for trying to help.
- Valdemar
valdemarb
Post by valdemarb »
Just wanted to let you know, that I found the culprit for the crashes. AS did not have access to the drive, where the pictures reside.
- Valdemar
