Can't change order of metadata fields
Bugs & Suggestions
Kneops
operating_system: Linux
System_Drive: N/A
motherboard: ASUS P8 Z68
processor: Intel i7 2600
Video Card: nVidia 450
sound_card: onboard
Hard_Drive_Capacity: 14 TB
Monitor/Display Make & Model: Dell U2713H & Spider4
Corel programs: ASP3
Post by Kneops »
When I add a custom set and fill it with the fields I need (moving them from the left to the right), I can then not order them in my new set.
When I move them up or down, the field is copied, not moved. When I then delete the one in the wrong place, it deletes the copy and the order is still the same as it was before.
Is this a bug?
http://storage5.static.itmages.com/i/14 ... 3dc01.jpeg
afx
System_Drive: N/A
Video Card: FirePro 4900
Re: Can't change order of metadata fields
Post by afx »
Bug...
You can edit the file (metaDataSets.xml) manually once you've copied over the relevant data.
It is in the appropriate locale directory in your user folder.
cheers
afx
Kneops
System_Drive: N/A
sound_card: onboard
Post by Kneops »
Ok, thanks, I will do it manually then. I assume this will be fixed whenever a new version comes out? Saves time ;)
afx
System_Drive: N/A
Post by afx »
No idea where on the priorities list this sits...
But generally, stuff for which a workaround exists is lower on the priority than stuff that has no workaround.
cheers
afx
