Videostudio X7 crashes adding transitions
harff
operating_system: Windows 8.1
Post by harff »
Hello, I've bought Videostudio X7 Update version. It crashes everytime I add a transition (with videos or pictures).
Can someone help me? :cry:
Thank's a lot.
Sorry for my English.
Stefano.
skier-hughes
Microsoft MVP
motherboard: gigabyte
ram: 4GB
sound_card: onboard
Hard_Drive_Capacity: 36GB 2TB
Re: Videostudio X7 crashes adding transitions
Post by skier-hughes »
Can you tell us what file types you are using?
Does it happen with every and / or any transition?
If you load two VS supplied videos does it crash when adding a transition?
harff
Post by harff »
It crashes with any transition using the samples videos provided with VS.
I've unistalled the previous X6 version and all the video codec... but I get the same crash (sorry it's in italian)
Firma problema:
Nome evento problema: APPCRASH
Nome applicazione: vstudio.exe
Versione applicazione: 17.0.0.249
Timestamp applicazione: 52bb478c
Nome modulo con errori: vstudio.exe
Versione modulo con errori: 17.0.0.249
Timestamp modulo con errori: 52bb478c
Codice eccezione: c0000005
Offset eccezione: 003637fa
Versione SO: 6.3.9600.2.0.0.256.103
ID impostazioni locali: 1040
Informazioni aggiuntive 1: 5861
Ulteriori informazioni 2: 5861822e1919d7c014bbb064c64908b2
Ulteriori informazioni 3: 4754
Ulteriori informazioni 4: 47547fafc9a3073a5bbe8e69322a8db5
Leggere l'informativa sulla privacy online:
http://go.microsoft.com/fwlink/?linkid=280262
Se l'informativa sulla privacy online non è disponibile, leggere quella offline:
C:\WINDOWS\system32\it-IT\erofflps.txt
harff
Post by harff »
Eventlog english version: :)
Problem signature:
Problem Event Name: APPCRASH
Application Name: vstudio.exe
Application Version: 17.0.0.249
Application Timestamp: 52bb478c
Fault Module Name: vstudio.exe
Fault Module Version: 17.0.0.249
Fault Module Timestamp: 52bb478c
Exception Code: c0000005
Exception Offset: 003637fa
OS Version: 6.3.9600.2.0.0.256.103
Locale ID: 1040
Additional Information 1: 5861
Additional Information 2: 5861822e1919d7c014bbb064c64908b2
Additional Information 3: 4754
Additional Information 4: 47547fafc9a3073a5bbe8e69322a8db5
harff
Post by harff »
Solved with SP1 :D
