ASP2 Batch Output Hangs
Bugs & Suggestions
bananahead
motherboard: Asus P67
processor: i7 2600k
Video Card: Nvidia 650
sound_card: Asus DX
Hard_Drive_Capacity: Lots
Monitor/Display Make & Model: NEC PA272W
Post by bananahead »
If I do an export of more than a few images then ASP2 hangs after about the third image. I then have to cancel the export and end up exporting one at a time. I have tried this with a number of batches and it is consistent.
OpenCL is switched off.
Does anyone else have this problem or possibly a solution?
afx
operating_system: Linux
System_Drive: N/A
Video Card: FirePro 4900
Re: ASP2 Batch Output Hangs
Post by afx »
Any plugin in use?
(I noticed that previews take oodles of time when I use WS...)
cheers
afx
df
ram: 64gb
Hard_Drive_Capacity: 1 Tb
Post by df »
Try starting a batch before you go to bed and let it hang. After 8 hours or so it will finally process the third image and zip through the rest. After that it should perform alright, even after restarts. At least that's what happened for me in the Beta. Your mileage may vary.
Regards, Dan
awm03
Post by awm03 »
Do you have the latest driver for your Nvidia graphics card?
http://www.nvidia.com/Download/index.aspx?lang=en-us
I had lots of problems using OpenCL -- crashes galore, so turned it off. But updating the Nvidia driver helped, so I could turn OpenCL back on, and all works smoothly.
