I am new here and I want to buy the VS Pro X7, so I tested it with my new GoPro Files. Before I made Video editing with older VS Versions, so I am not that new in this hobby.
Now I have a problem with my 1080p 29,97fps Gopro records when I render them into 1080p 29,97 videofiles (varies of codecs, always the same problem). As soons as the video gets rendered in one of the codecs and smart rendering cant get used, inthis very moment the resulting fine video stutters like I would have an unsynched output (like playing a 29,97fps file with a 25fps monitor...)
Before my conditions:
Rendering PC:
I5-760
8gb DDR1600
256gb System SSD (and 500gb Raid-0 internal disks for local working)
external 4gb WD Nas-drive for raw records and resulting videos (used for the testfiles below)
Player System:
Rendering PC OR HTPC with OpenElec/XBMC (i3, 4gb DDR1333, Nvidia 630GT, frame-synced video output!!!! to Panaconic Full-HD TV)
Camera
GoPro HD3+ Black Edition
Now my testfiles:
File: (record)
00_GoProRecord_1080p_2997fps.mp4
Rendering setting in VS7:
none, since it is the raw material
behavier:
runs fluent, no stuttering on any playback device
Mediainfo:
Code: Select all
Allgemein
Vollständiger Name : E:\test\00_GoProRecord_1080p_2997fps.MP4
Format : MPEG-4
Format-Profil : JVT
Codec-ID : avc1
Dateigröße : 226 MiB
Dauer : 1min 2s
Modus der Gesamtbitrate : variabel
Gesamte Bitrate : 30,3 Mbps
Kodierungs-Datum : UTC 2014-05-29 12:42:35
Tagging-Datum : UTC 2014-05-29 12:42:35
AMBA :
Video
Format : AVC
Format/Info : Advanced Video Codec
Format-Profil : High@L4.1
Format-Einstellungen für CABAC : Ja
Format-Einstellungen für ReFrames : 1 frame
Format_Settings_GOP : M=1, N=15
Codec-ID : avc1
Codec-ID/Info : Advanced Video Coding
Dauer : 1min 2s
Bitraten-Modus : variabel
Bitrate : 30,0 Mbps
Breite : 1 920 Pixel
Höhe : 1 080 Pixel
Bildseitenverhältnis : 16:9
Modus der Bildwiederholungsrate : konstant
Bildwiederholungsrate : 29,970 FPS
ColorSpace : YUV
ChromaSubsampling : 4:2:0
BitDepth/String : 8 bits
Scantyp : progressiv
Bits/(Pixel*Frame) : 0.483
Stream-Größe : 225 MiB (99%)
Titel : GoPro AVC
Sprache : Englisch
colour_primaries : BT.709
transfer_characteristics : BT.709
matrix_coefficients : BT.709
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format-Profil : LC
Codec-ID : 40
Dauer : 1min 2s
Bitraten-Modus : konstant
Bitrate : 128 Kbps
Kanäle : 2 Kanäle
Kanal-Positionen : Front: L R
Samplingrate : 48,0 KHz
Stream-Größe : 979 KiB (0%)
Titel : GoPro AAC
Sprache : Englisch
Andere
Type : Time code
Format : QuickTime TC
Dauer : 1min 2s
TimeCode_FirstFrame : 12:41:48:08
TimeCode_Settings : Striped
Sprache : Englisch
File:
01_GleichWieErsterClip_SRan.mp4
"like first video clip" + smart rendering activated
behavier:
Mediainfo:
Code: Select all
Allgemein
Vollständiger Name : E:\test\01_GleichWieErsterClip_SRan.mp4
Format : MPEG-4
Format-Profil : Base Media
Codec-ID : isom
Dauer : 1min 2s
Gesamte Bitrate : 30,2 Mbps
Kodierungs-Datum : UTC 2014-06-02 17:45:50
Tagging-Datum : UTC 2014-06-02 17:45:50
Video
Format : AVC
Codec-ID : avc1
Dauer : 1min 2s
Bitrate : 30,0 Mbps
Höhe : 1 080 Pixel
ColorSpace : YUV
Stream-Größe : 225 MiB (100%)
Sprache : Englisch
Audio
Format : AAC
Format-Profil : LC
Codec-ID : 40
Dauer : 1min 2s
Bitrate : 128 Kbps
Kanäle : 2 Kanäle
Sprache : Englisch
File:
02_GleichWieErsterClip_SRaus.mp4
"like first video clip" + smart rendering deactivated
behavier:
stutters on every Playback device (not a CPU or GPU or Screenproblem!)
Mediainfo:
Code: Select all
Allgemein
Vollständiger Name : E:\test\02_GleichWieErsterClip_SRaus.mp4
Format : MPEG-4
Codec-ID : isom
Dateigröße : 207 MiB
Dauer : 1min 2s
Gesamte Bitrate : 27,7 Mbps
Kodierungs-Datum : UTC 2014-06-02 17:42:39
Tagging-Datum : UTC 2014-06-02 17:42:39
Video
Format : AVC
Format-Einstellungen für ReFrames : 2 frames
Format_Settings_GOP : M=3, N=15
Codec-ID : avc1
Dauer : 1min 2s
Bitrate : 27,6 Mbps
maximale Bitrate : 30,0 Mbps
Höhe : 1 080 Pixel
Standard : NTSC
ColorSpace : YUV
Bits/(Pixel*Frame) : 0.444
Stream-Größe : 206 MiB (100%)
Sprache : Englisch
Audio
Format : AAC
Format-Profil : LC
Codec-ID : 40
Dauer : 1min 2s
Bitrate : 128 Kbps
Kanäle : 2 Kanäle
Stream-Größe : 982 KiB (0%)
Sprache : Englisch
File:
03_h264_25mbps_2pass_2997fps_SRan.m2t
"AVC/h.264"-"h264"-"25mbps"-"2-pass"-"1920x1080"-"29.97fps"-"picture based(progressiv, dont know the english translation)"-"smart rendering on/off makes no difference"
behavier:
Mediainfo:
Code: Select all
Allgemein
Vollständiger Name : E:\test\03_h264_25mbps_2pass_2997fps_SRan.m2t
Format : BDAV
Format/Info : Blu-ray Video
Dateigröße : 173 MiB
Dauer : 1min 2s
Gesamte Bitrate : 23,2 Mbps
maximale Gesamtbitrate : 31,6 Mbps
Video
Menü-ID : 1 (0x1)
Format : AVC
Format-Profil : High@L4.0
Codec-ID : 27
Dauer : 1min 2s
Bitrate : 22,1 Mbps
maximale Bitrate : 25,0 Mbps
Höhe : 1 080 Pixel
Standard : NTSC
ColorSpace : YUV
Bits/(Pixel*Frame) : 0.355
Stream-Größe : 165 MiB (95%)
Audio
Menü-ID : 1 (0x1)
Format : AC-3
Format/Info : Audio Coding 3
Format_Settings_ModeExtension : CM (complete main)
Format-Einstellungen für Endianess : Big
Codec-ID : 129
Dauer : 1min 2s
Bitrate : 256 Kbps
Kanäle : 2 Kanäle
BitDepth/String : 16 bits
Stream-Größe : 1,91 MiB (1%)
File:
04_mpeg2_25mbps_2pass_2997fps_SRan.m2t
"AVC/h.264"-"mpeg2"-"25mbps"-"2-pass"-"1920x1080"-"29.97fps"-"picture based(progressiv, dont know the english translation)"-"smart rendering on/off makes no difference"
behavier:
Mediainfo:
Code: Select all
Allgemein
Vollständiger Name : E:\test\04_mpeg2_25mbps_2pass_2997fps_SRan.m2t
Format : BDAV
Dateigröße : 183 MiB
Dauer : 1min 2s
Gesamte Bitrate : 24,5 Mbps
Video
Menü-ID : 1 (0x1)
Format : MPEG Video
Format-Version : Version 2
Format-Profil : Main@High
Format-Einstellungen für BVOP : Ja
Format-Einstellungen für Matrix : üblich
Codec-ID : 2
Dauer : 1min 2s
Bitrate : 23,3 Mbps
Höhe : 1 080 Pixel
ColorSpace : YUV
Bits/(Pixel*Frame) : 0.374
TimeCode_FirstFrame : 00:00:00:00
TimeCode_Source : Group of pictures header
Stream-Größe : 174 MiB (95%)
Audio
Menü-ID : 1 (0x1)
Format : AC-3
Codec-ID : 129
Dauer : 1min 2s
Bitrate : 256 Kbps
Kanäle : 2 Kanäle
Here the DL Link: http://netload.in/dateiSoFDCr9YMZ/testfiles.zip.htm
