Rotopen
mwsing
- motherboard: Dell Inc 0C2KJT A00
- processor: 2.93 Gigahertz Intel Core i3 530
- ram: 6 gigabyte
- Video Card: NVIDIA GeForce310
- Hard_Drive_Capacity: 500 GB
- Monitor/Display Make & Model: Viewsonic VX2240W
Rotopen
I have just installed Videostudio X7 and am trying to use Rotopen to draw a route on a map, For some reason, when I replay the clip with the route, the route starts about a centimetre (on the preview window) from where I actually started and I cannot see any reason why this should be so. I did not have this problem with Videostudio X5. Any ideas anyone?
- RobertOZ
- Hard_Drive_Capacity: 7 TB
Re: Rotopen
Make sure that your map matches the project properties frame size, if your project is 1280x720, then your map should also be 1280x720. Rotopen will then follow the route correctly.
Robert
Robert
Re: Rotopen
Hi guys
I am not sure that the frame size has to match in pixel dimensions, but the aspect ratio has to match,
Your project is probably 16:9, your map image should use the same ratio.
It is possible that your image is 3 x 2
mwsing
- ram: 6 gigabyte
Re: Rotopen
Thank you both for your help. What is the best way to ensure that they have the same attributes? I tried copying the attributes from the previous clip, but that did not work. I then used a program from the web to resize the photograph so that the aspect ratio is 16x9. This seemed to work fine.
Re: Rotopen
Resizing the image to use a ratio of 16:9 is the only way to make the Rotopen stay on line.
If you were to use a project having a 4:3 size then your image should also be 4:3
mwsing
- ram: 6 gigabyte
Re: Rotopen
Thanks Trevor - that's what I did andit works fine
Ken Veal
- motherboard: msi mpg z390 gaming edge ac lga 1151 ddr4
- processor: 360 gigahertz Intel Core i9 900K
- ram: 32 GB
- Video Card: EVGA GeForceGTX 760 2GB GDDR5 PCI E 3 0
- Hard_Drive_Capacity: 1250GB SSD
- Monitor/Display Make & Model: Samsung U28E90 28” UHD 4k
- Corel programs: PaintSPro2021Ult.PhotoMirage.VS.2020 Ult
Re: Rotopen
I read this post with interest as it mirrors the problem I have exactly even to quoting no prob with X5.I requested help in http://forum.corel.com/EN/viewtopic.php ... 40#p295140 and part of the reply I got was “ your video is a pretty standard 16:9 format - but your image is almost square.
I would just crop the image to a 16:9 ratio in Paint Shop Pro - something like 775 x 436 pixels before putting it into Video Studio” Bearing in mind what has been said here and doing the above cropping did not solve my problem, can any one advise me further please
mwsing
- ram: 6 gigabyte
Re: Rotopen
I used "Resize your image on line" and resized my image to 595x335. This resolved the problem for me.
