i'm running 64bit asp2 on debian jessie under kde and none of the main program window management works properly...
they've chosen to implement their own window borders and title bar (unlike asp1, which used the native window borders worked fine) but i cannot move the window by dragging the (faux) titlebar and also the window has no borders to allow for resizing.
also after switching to full screen and back i now find that the asp2 window always opens full screen, no matter how i had it sized and placed before i closed it...
i'm also getting corrupt thumbnails for some images that were fine under asp1, but i guess that'll be a subject for another bug report if i can even get this barely useable by solving the above issues to have a properly manageable program main window.
beginning to regret purchasing this upgrade.
asp2 linux kde - window management complete fail
afx
- System_Drive: N/A
- Video Card: FirePro 4900
Re: asp2 linux kde - window management complete fail
Which is ugly as hell.elguavas wrote:they've chosen to implement their own window borders and title bar
Works like any other application with XFCE (Xubuntu 14.04). No issues there....(unlike asp1, which used the native window borders worked fine) but i cannot move the window by dragging the (faux) titlebar and also the window has no borders to allow for resizing.
Granted, the sensitive borders are slim....
Can't reproduce that on XFCE.also after switching to full screen and back i now find that the asp2 window always opens full screen, no matter how i had it sized and placed before i closed it...
cheers
afx
ok, i took kde completely out of the equation by running asp2 under fluxboxafx wrote:Can't reproduce that on XFCE.
i finally got it working properly again by deleting ~/.config/Corel/Aftershot Pro.conf and re-starting. of course that meant i had to register again too.
i'm a bit dubious about this now, but anyway if anyone searches on a similar problem and finds this thread my workaround is recorded above.
hardaker
- System_Drive: B
- processor: Intel Core i7-2760QM
- Video Card: NVidia Quadro 1000M
- Hard_Drive_Capacity: 1.25TB
Ah, that was enough to get me going to get me out of the jam (also on KDE).elguavas wrote:i finally got it working properly again by deleting ~/.config/Corel/Aftershot Pro.conf and re-starting.
I changed these two lines to false (they were true):
Code: Select all
FramelessWindow\Maximize=false
FramelessWindow\fullscreen=false
