Problems cutting and pasting colour balance
Jord
- Hard_Drive_Capacity: Chester
Re: Problems cutting and pasting colour balance
Has anyone else got a similar issue?
afx
- System_Drive: N/A
- Video Card: FirePro 4900
At the moment Linux. I'll be on a Windows box hopefully later today.
cheers
afx
cheers
afx
afx
- System_Drive: N/A
No problems on the W7 box with AS2 32bit either....Jord wrote:No idea - are you on Windows 64bit?
cheers
afx
mikkokan
- System_Drive: N/A
First post here!
I have the same problem. I've used Bibble4-5-ASP1 and now paid for the ASP 2 upgrade and I faced this problem.
If i choose one raw photo and press CTRL+C and then goto next image and press CTRL+V the white balance changes from "as shot" to "custom".
If I for example has an image that has WB 4900 straight from the camera and I leave the setting "as shot". Now I copy this image settings. When I paste the settings to the next image I have WB 4900 "custom" even if it really should be 5200 if it would stay "as shot".
Hope somebody understand my english. For now I must go back to ASP 1 to work...
Jord
OK on this weeks wedding I applied the batch setting in ASP1 and all is well - processing in ASP2 and the applied batch settings are as they should be. But on single images if I press CtrlC the white balance changes to custom even if the source photo is showing as shot. Most annoying.
Any ideas - and at least I know it not just me!!
afx
- System_Drive: N/A
Which is a much better behavior than the old nonsense of just copying the As-Shot flag.mikkokan wrote:If i choose one raw photo and press CTRL+C and then goto next image and press CTRL+V the white balance changes from "as shot" to "custom".
Because typically you want to copy the actual WB not the instruction to use As-Shot.
cheers
afx
mikkokan
- System_Drive: N/A
Really?
For example yesterday I had 1902 raw files to process. Most of these were taken inside where partly light came in from windows, then on the other side there was no windows but lightbulbs and because of this WB was different in every photo. So in same room I had sun, bulbs and something between those two. This is very typical scenario in weddings.
So now I must go throught every single 1902 photo and change WB to "as shot"?
If I want to copy the actual WB value I could change it manually when the flag is "custom" and then copy that to other pictures. That how it worked in ASP 1.
This kind of behaviour makes photo process way too slow for professional needs. I dont have time to edit every single image, thats why we have this copy/paste->batch workflow.
afx
- System_Drive: N/A
No.mikkokan wrote:For example yesterday I had 1902 raw files to process. Most of these were taken inside where partly light came in from windows, then on the other side there was no windows but lightbulbs and because of this WB was different in every photo. So in same room I had sun, bulbs and something between those two. This is very typical scenario in weddings.
Use selective copy.
Yup, a major PITA. There have been enough complaints about this in B5 already.If I want to copy the actual WB value I could change it manually when the flag is "custom" and then copy that to other pictures. That how it worked in ASP 1.
Users expect expect the actual WB copied not some flag.
Sorrry, do not talk about speed when you do not even know the basic tools.This kind of behaviour makes photo process way too slow for professional needs. I dont have time to edit every single image, thats why we have this copy/paste->batch workflow.
And, this also begs the question, why do you need to explicitly set As-Shot anyway? It is the default?
cheers
afx
mikkokan
- System_Drive: N/A
Ok, thanks I didn't know that I could use selective copy and uncheck WB from there if want to leave pictures "as shot". A much slower way though...
Some users want to copy flags like me. If I want to copy some value I use custom WB, no problem.Users expect expect the actual WB copied not some flag.
It is but not anymore when I paste image settings. The behaviour changed between ASP1->ASP2.And, this also begs the question, why do you need to explicitly set As-Shot anyway? It is the default?
Don't be sorry, its always nice to hear not to know even basics!Sorrry, do not talk about speed when you do not even know the basic tools.
afx
- System_Drive: N/A
Much slower? three clicks more....mikkokan wrote:Ok, thanks I didn't know that I could use selective copy and uncheck WB from there if want to leave pictures "as shot". A much slower way though...
And still, faster than doing it individually.
And you could always set up a Copy-Set for this if you find yourself doing it all the time, so you have dedicated hotkeys for the stuff you want to copy instead of going through menus.
But what is the expectation of the average guy? Usually to have the same WB in the copy as in the original. So your use case is the exotic one.Some users want to copy flags like me. If I want to copy some value I use custom WB, no problem.Users expect expect the actual WB copied not some flag.
Let me reword this...It is but not anymore when I paste image settings. The behaviour changed between ASP1->ASP2.And, this also begs the question, why do you need to explicitly set As-Shot anyway? It is the default?
All image adjustments that handle color or luminance depend on the white balance. So it makes no sense to copy all image adjustments but not the actual WB in most cases.
If you do not want WB copied, then use Selective Copy or Copy-Sets.
cheers
afx
mikkokan
- System_Drive: N/A
Three clicks vs zero clicks
But I'll have to check if I could make some hotkey to make it easier.
We see things in different way, best option would be a setting that one could choose how copy/paste works.
Pictures:
1-100=outside (autolevel, sharpening 100)
100-120=inside pictures of decoration (sharpening 100, noise ninja 4, saturation +10...)
120-200=inside random pictures of moments (sharpening 100, fill light +30, noise ninja 8 )
And so on. Always in these example WB can be left "as shot" but everything else are different. List goes on 0-1500 usually.
Yes it's fine when I process studio photos or portraits taken outside but when processing photos taken inside that has different light sources in one room then this new way of copying just WB value doesn't work. Maybe it's just me but I liked the ASP1 way better.But what is the expectation of the average guy? Usually to have the same WB in the copy as in the original. So your use case is the exotic one.
Lets take example of a weggind ceremony:All image adjustments that handle color or luminance depend on the white balance. So it makes no sense to copy all image adjustments but not the actual WB in most cases.
Pictures:
Jord
Hi AFX
I really do not understand where you are coming from - if I have a 1000 images and I want each image to have the same sharpening, contrast ect I do not want to alter the White Balance, if I wanted to alter the WB I would and then Cut and paste. It not a case of one extra click it a case of a 1000 extra click on every image whereas if it would behave as it did on AS1 most images I would just click next. My camera gets the WB correct 90% of the time - I have no desire to chage the WB on these.
I find it a little patronising to say the least! I know how to do my job as I am sure others who have complained also. If the WB is left unchanged in the original I want to paste it as unchanged (i.e. as shot) if I want to change it to a custom WB I'll change it then cut and paste the settings.
I find myself going back to use AF1 and feel I have wasted the money on an upgrade as it in no way speeds up my workflow. Infact it doubles the time spent.
Is it not too much to ask to just revert the cut and paste procedure back to AS1 protocole?
Kind Regards.
Kind Regards.
afx
- System_Drive: N/A
If you copy all and everything, then you do have exposure and color adjustments in there as well, does not make much sense if your focus is sharpening / contrast.Jord wrote:I really do not understand where you are coming from - if I have a 1000 images and I want each image to have the same sharpening, contrast ect I do not want to alter the White Balance, if I wanted to alter the WB I would and then Cut and paste.
That's where copy sets make life much easier.
It is one extra click in selective copy to exclude WB...It not a case of one extra click it a case of a 1000 extra click on every image
And with an appropriate copy set it is even faster.
Claiming it needs to be done on individual images is nonsense.
Sure, just copy stuff you need but not WB.whereas if it would behave as it did on AS1 most images I would just click next. My camera gets the WB correct 90% of the time - I have no desire to chage the WB on these.
Well, the majority wants WB copied if they copy all image settings...I find it a little patronising to say the least! I know how to do my job as I am sure others who have complained also. If the WB is left unchanged in the original I want to paste it as unchanged (i.e. as shot) if I want to change it to a custom WB I'll change it then cut and paste the settings.
That is a bug that has been in B5 already.
Well, the AS1 behavior was broken and they finally fixed it.Is it not too much to ask to just revert the cut and paste procedure back to AS1 protocole?
One of the positive things in AS2...
cheers
afx
mikkokan
- System_Drive: N/A
For example Darktable respects original WB (as shot) when I copy/paste. Without thinking and making extra clicks.
I don't think that's a bug or the programs behaviour is broken.
Jord
I really am totally frustrated and can't understand if you have image settings you want to copy and past why it would change the wb. If I have altered the wb fine but if I haven't why change it? I've reverted back to AP1 and feel talking to the Corel moderators on here is equivalent to banging my head against a wall.
So how do I do a preset - I untick wb so it will not copy it yet it changes every single image anyway.
Just to reinitiate if I want do want WB copied if I have had to alter it but not if it is listed as shot. So As shot is the setting I am copying! 'AS SHOT IS WHAT I AM COPYING!
I know it a total waste of time even checking back as you basically don't seem to give a toss on your customers views.
A very disapointed user - and I have used the packed since Bibble days and always been perfectly happy.
