Just saw there was an ASP v2 and initially it looks good, but I can't get the plugins to appear. I downloaded the trial version.
I have tried just copying the folders to the appropriate place.
I ave also tried installing from ASP ('File' - 'Install Plugins'). I installed all the plugins and if I try to re-install it says the plugins are already installed.
However they do not show up in the panel and if I go to 'Help' - 'System Info' they do not show up as installed.
The B&W and Equalizer plugins show up and if I remove the folders from the plugin folder they also disappear, but non of the others show up at all.
I think I'd like to upgrade, but I absolutely need the plugins. Anyone know what is going on or been able to use the old plugins with v2?
Plugins in ASP 2
EdwardJenner
- motherboard: Dell Inc. 04YY4M A00
- processor: 2.70 gigahertz Intel Core i7-2960XM
- Video Card: NVIDIA Quadro 4000M
- Hard_Drive_Capacity: 1.25TB
- Monitor/Display Make & Model: Generic PnP Monitor (17.3"vis)
afx
- System_Drive: N/A
- Video Card: FirePro 4900
Re: Plugins in ASP 2
