No Noise reduction no hightlight recovery on sRAW and MRAW
Bugs & Suggestions
AsterixEtObelix
operating_system: Linux
System_Drive: N/A
motherboard: Debian squeeze 64
processor: Intel
Post by AsterixEtObelix »
Hello,
beside the discussion mRAW and sRAW are not RAW format, there are hudge regression with those canon format.
1) The Highlight recovery is not accessible. It can be set without problem on ASP 1.X and was working fine. On ASP 2 the slider is not accessible.It is greyout. So it is impossible to reconstruct highlights.
2) There is no access to the "RAW noise" feature.
3) ASP 2 crashes when moving any slider on "Noise reduction by Athentech"
Those 2 formats are shown as "cameras supported" on Corel website. Noise reduction and hightlight recovery are really a basic feature of a RAW program. No having them is purely and simply useless.
Both format are not working on a Canon 40D and canon 5D mkII
I am happy to send some sample RAW if need. I hope it will be corrected soon because right now ASP 2 is pretty useless for half of my pictures. I am used to take half of my pictures in mRAW or sRAW.
josephlin
Alludo
motherboard: Intel Z490 chipset
processor: Intel Core i9-10900K
ram: 32GB
Video Card: nVidia RTX 2070S
sound_card: Realtek ALC892
Hard_Drive_Capacity: SSD 1TB
Re: No Noise reduction no hightlight recovery on sRAW and MR
Post by josephlin »
Hi there, we are collecting all issue reports from ASP2 launch and your issue seems like is another one that we will take care of working as high priority. If you don't mind, could you please share your content from dropbox or somewhere that we can access. Then please send the link to "paintshop@corel.com" and we will take care of it ASAP. Thank you.
Cheers
Joseph Lin
Sr. Program Manager,
Corel PaintShop Pro / AfterShot Pro / VideoStudio
AsterixEtObelix
System_Drive: N/A
processor: Intel
Thanks you for your reply.
I just send you a mail with a short explanation and some samples which explain the problem. I just discovered aslo that on sRAW there are artifact also (see below)...
I took some sample of pictures which are overexposed and some others samples with a lot of noises. Additionally I took those pictures in both format "full RAW " and sRAW.
All my RAW + xmp can be downloaded there :
https://www.dropbox.com/s/niyorm29teenj ... rsASP2.zip
Using ASP2 with an sRAW it is not possible to use highlight reconstruction ( by the way I just discovered now the artifact):
one sample preprocess with ASP1
the same sample where highlight reconstruction is not working with ASP2 + artifacts :
I the zip file there are also some noisy sRAW (as well as normal RAW) taken with a Canon 5D mMK II and a 40D On debian 64bits it just make ASP2 to crash
