Before and After view
Tips, Tricks, and Results
Tuvok
Hard_Drive_Capacity: 2TB
Corel programs: ASP3, PSP2019, PhotoMirage, ParticleShop
Post by Tuvok »
Hello,
Does AF have a Before/After view, and what is its shortcut?
afx
operating_system: Linux
System_Drive: N/A
Video Card: FirePro 4900
Re: Before and After view
Post by afx »
Not directly.
Indirectly you could Use CTRL-R and then toggle back with CTRL-Z
Or create a version and then reset that with CTRL-R and view it in multiview mode.
cheers
afx
Trev
operating_system: Windows 8.1
ram: 32GB
Hard_Drive_Capacity: 4Tb
Post by Trev »
Yes there is!
I am a recent convert to ASP2 - what a great program and today asked myself this very question 'How do I see what the photo was like before I started to tinker with it?'
Use the History view - CTRL+SHIFT+H
Click on Initial settings to see the original photo and click on any of the others listed to see how the changes you used were applied
Click the bottom of the list ie last change to see the latest view
If you are using the File view the history is not saved from this session - use the Library to save History with the photo.
regards
Trev
dattanchu
processor: i5 2500K
ram: 16g
Post by dattanchu »
Cool. Thank you Trev. This looks like it is simple enough to write a Before/After plugin for?
