I'm trying to do a Canvas Size adjustment on an image. However, when I specify new figures in the Width and Height fields, all of the Placement fields populate accordingly except for the Left field.
For example, I have an image sized 300 x 300. I'm trying to take 50 pixels off both height and width, but observe the figures in the image.
I also tried checking "Lock Aspect Ratio" but it doesn't even out the numbers.
Has anyone else had a problem with this?
I guess I'll just have to do a workaround: Select All, Contract Selection and crop that way.
Canvas Size bug
Canvas Size bug
- hartpaul
- ram: 8 Gb
Re: Canvas Size bug
If I was trying to make the canvas from 300 square to 250 square I would use Image > Resize.
If I was trying to remove excess around edges to get to 250 square you could use the crop tool, or Selection select a square , invert and delete key , selections none
Re: Canvas Size bug
I'm glad to know the alternatives to the Canvas Size tool.
Back on topic -- what is the issue with the Canvas Size tool? I don't remember it behaving this way in previous versions of PSP.
Is anyone aware of as to why?
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
Re: Canvas Size bug
I'm unable to duplicate this issue. Which version of PSP are you using? If it's X6 are you using the 32-bit or 64-bit version or does it happen in both?
Is there a difference between a background layer and a raster layer? Does the image have any additional layers?
- Tony Lenton
- motherboard: Intel DH55TC
- processor: Intel Core i5 3.20 GHz
- ram: 12GB
- Video Card: GeForce GTX 1060
- sound_card: On board Realtek High Def Audio
- Hard_Drive_Capacity: 4500 GB
- Monitor/Display Make & Model: Lenovo S27i
- Corel programs: PSP X6 PSP2020
Re: Canvas Size bug
What happens when you click on the Centre button under Placement?
LindaSue
- motherboard: Gigabyte
- processor: 2.71GHz AMD Athlon II X2 215 processor
- ram: 3 GB
- sound_card: Realtek AC97 Audio [onboard]
- Hard_Drive_Capacity: 1320 GB
- Monitor/Display Make & Model: Asus MX279 HDMI 27-inch
- Corel programs: Paint Shop Pro X2, X4, X6
Re: Canvas Size bug
What's odd is that none of your Placement buttons appear to be selected. Perhaps PSP is remembering a previous setting from another image. Try selecting your placement and see what happens.
Using Paint Shop Pro versions 5, 6, 7, 8, 9, 12, 14, 16
Re: Canvas Size bug
I confirmed that the bug is consistent between the 32 and 64-bit versions. Then I selected the Center Placement button and the numbers evened themselves out. I'm guessing that in my previous product -- PSP X1 -- this button was already selected. Every Canvas Size operation seemed to number up correctly.
I will leave this button engaged and let you know if something goes awry.
I can't help but wonder: with no Placement selected, where the heck does it get those numbers from?
Anyhoo. Thanks for the solutions!
Zacabeb
- motherboard: ASUS B450-F
- processor: AMD Ryzen 5 3600
- ram: 16 GiB
- Video Card: nVidia GeForce RTX 2060
- sound_card: RealTek Integrated Audio
- Hard_Drive_Capacity: 3 TB
- Monitor/Display Make & Model: Philips 236V4
- Corel programs: PaintShop Pro X6, PaintShop Pro 2021
Re: Canvas Size bug
It looks like it uses the original canvas size to calculate the left offset. So if it was 400 pixels wide, it would fill in the left offset box with -399 and so on.
Re: Canvas Size bug
I'm using PaintShop Pro X6. I've had it for almost a year and never had this problem until recently. When I use the resize canvas tool, my picture disappears and I'm left with a blank canvas.
