Any Linux 64bit ASP2 successfully run....?
Bugs & Suggestions
tjm3
operating_system: Linux
System_Drive: N/A
Post by tjm3 »
If so, I would really like to know what your configuration is, what distribution, kernel version and window manager to narrow down the problem of not being able to start and run ASP2 64bit Linux.
thanks,
tjm
manu-p
System_Drive: N/A
processor: AMD 64 X2 Dual Core 4200+
Video Card: nVidia Ge Force GT 620
Re: Any Linux 64bit ASP2 successfully run....?
Post by manu-p »
It runs on my side : Ubuntu 12.04.4 with Unity.
Linux manubuntu 3.2.0-61-generic #93-Ubuntu SMP Fri May 2 21:31:50 UTC 2014 x86_64 x86_64 x86_64 GNU/Linux
Any message in a terminal on your side ?
afx
System_Drive: N/A
Video Card: FirePro 4900
Post by afx »
Xubuntu 14.04 64bit on a Lenovo Thinkpad with a quad i7.
But why bother with 64bit? Install 32bit where currently most plugins are available in contrast to 64bit.
Nothing special. Even the silly Nvidia card works at lower strength level with OpenCL. Have not tested the speed though, with AS1 it was slower than CPU only.
If you start form the terminal, what are the last lines?
What distro are you using?
cheers
afx
tjm3
System_Drive: N/A
Post by tjm3 »
I'm using Debian 7 Wheezy with all current updates.
A terminal run shows a segfault after trying to start the catalog manager.
dmesg shows the error to be libQtSql.so.4.8.2 . ASP2 loads libQtSql.so.4.7.3
in its lib directory so the problem is/was libQt version 4.8.2.
Works fine after pointing the program to the earlier libs that came with ASP.
My suggestion would be to link to the later directories if possible.
What version of libQt is the Ubuntu dist using?
afx
System_Drive: N/A
Post by afx »
Ubuntu ships 4.8.5.
But the AfterShotpro2 setup script handles the libpath appropriately, so I wonder what is going on on your side.
cheers
afx
tjm3
System_Drive: N/A
Post by tjm3 »
afx wrote:Ubuntu ships 4.8.5.
cheers
afx
Evidently nothing is out of the ordinary. I found the startup script you suggested in /usr/bin and it works perfectly.
thanks,
tjm
kewerner
System_Drive: N/A
ram: 32GB
Video Card: NVidia
Post by kewerner »
Got it running after some inital hiccups (export didn't work). Now, if only the plugins would be 64 compatible: as it is now, it's unusable for production purposes.
GeForce GT 640/PCIe/SSE2
Intel® Core™ i7-3770 CPU @ 3.40GHz × 8
64-bit / 32GB RAM
AsterixEtObelix
System_Drive: N/A
motherboard: Debian squeeze 64
processor: Intel
Post by AsterixEtObelix »
Hello,
i succeed to install it on Debian Wheezy (7.x) 64bit out of the box. I am using also NVIDIA proprietary drivers.
Nevertheless it crash all the time when I am using the "Perfectly Clear Noise removal" feature.
[EDIT] : I succeed to install out of the box also ASP2 32bit on my debian system.
Kneops
System_Drive: N/A
motherboard: ASUS P8 Z68
processor: Intel i7 2600
Video Card: nVidia 450
sound_card: onboard
Hard_Drive_Capacity: 14 TB
Monitor/Display Make & Model: Dell U2713H & Spider4
Corel programs: ASP3
Post by Kneops »
I'm using it on Linux Mint 14 64bit and until now no problems. Except that I do not use the red X button in the top right corner to close the program, otherwise the next time it will present me with a blank screen and I have to close it again by using the quit button in the file menu. After that it says there was a fatal error and asks me to restore settings.
Edit: I just upgraded/new install with Linux Mint 17 64 bit and no problems, except that the window of ASP has nog rounded border like the other programs.
mc0e
System_Drive: N/A
motherboard: Lenovo 4286CTO
processor: Intel i7-2620M 2.70GHz
Video Card: 2nd Generation Core Processor Family Integrated Gr
sound_card: 6 Series C200
Hard_Drive_Capacity: 500GB
Monitor/Display Make & Model: Dell 2407WFPb
Post by mc0e »
The startup script is only partially successful for me. Yes, it sets LD_LIBRARY_PATH to include "/opt/AfterShotPro2(64-bit)/lib", which allows ASP2 to run. However, this environment variable is not unset when other programs are run. Eg post processing batch output fails, and is definitely for this reason. I haven't yet verified the cause, but running an external editor, or firing up a browser for the help pages also fail, and I expect it's probably for the same reason.
afx
System_Drive: N/A
Post by afx »
Well, the workaround is easy ;-)
I've put that in the tracker.
cheers
afx
dFlyer
System_Drive: N/A
Post by dFlyer »
Works well with Ubunut 14.04 on HP Pavilion g series. Just no 64bit pluggins yet.
Thanks.
Gary Garibaldi
Linux since 96
Sony a700
Sony a100
tjm3
System_Drive: N/A
Post by tjm3 »
OK, then.
That was v2.0.0.133.
v2.0.1.5 update also works 32/64bit on Debian stable.
How about v2.0.2.10? 32 bit works on Debian stable (Wheezy) but not amd64. Some sort of libc version mismatch.
I posted more info in the 'bugs' section.
dFlyer
System_Drive: N/A
Post by dFlyer »
Did you try the ASP2_LinuxDEB64_Patch01.deb which was posted under the patches and update section at the same time the 2.0.2.10 was released? I didn't have any problems with Ubuntu so didn't install the Patch01.deb. Looking at the contents of the patch lists libs. You might want to give it a try.
Thanks.
Gary Garibaldi
Linux since 96
Sony a700
Sony a100
tjm3
System_Drive: N/A
Post by tjm3 »
Thanks for that info. I never saw that patch. Looking now. Results soon.
Maybe not soon enough. Can't find that file but there is an update link that dead-ends.
Don't have the time for the endless loop support right now. I'll investigate some other time.
tm
