PSP X6 text problem
Norfolkman6
motherboard: Lenovo LNVNB161216 U3E1
processor: Intel Core i3
ram: 4GB
Video Card: Generic PnP Monitor on Intel HD Graphics 620
sound_card: Speaker HP Realtek High Definition Audio
Hard_Drive_Capacity: 1TB
Monitor/Display Make & Model: Generic PnP Monitor on Intel HD Graphics 620
Corel programs: PSP X3 X5 X6 X7 X8 X9 PSP2019
PSP X6 text problem
Post by Norfolkman6 »
Acer laptop with Win 7 PaintShop Pro X6 64bit version
I have just installed X6. In order to explain the problem in simple terms, I made the following experiment:
I have a jpg image which is simply a plain white background with the words SATURDAY EVENING on it in colour red and spread about halfway across the page. If I open that image in PSP X6 and then use the paintbrush (set to white) to paint out the wording, as soon as I click on another tool, for example the Pan tool or Pick tool, the first part of the wording re-appears! The same thing happens if I use the clone tool to remove the writing. As I said this was just an example but with other image files, the same thing happens and a part of the wording re-appears. I am sure that I am missing a simple trick somewhere.
I have used this method with X3 & X5 for years and never come up against this problem.
Any help would be much appreciated.
Geoff
MarkZ
ram: 8 GB
Hard_Drive_Capacity: 500 GB
Re: PSP X6 text problem
Post by MarkZ »
Are you zoomed in when you use the brush? Try doing the same thing with the image smaller than filling the window. I've had the same sort of effect when I zoom in on an area and use a tool. It's a bug.
Mark
Norfolkman6
ram: 4GB
Thanks Markz.
You are right, It does occur when I am zoomed in. I hadn't noticed that.
Glad I'm not the only one to experience it. Hope they fix it in a later update.
