- coat-RT.jpg (119.24 KiB) Viewed 10076 times
AfterShot Pro 2.0
Re: AfterShot Pro 2.0
RawTherapee NR:
scorpi11
- System_Drive: Q
- processor: Intel Core i5-2400
- Video Card: Intel HD2000
- Monitor/Display Make & Model: Eizo S2110W
I already tried, without success:afx wrote:Why not open up an extra thread on the specific issues?scorpi11 wrote:Is there anyone I can talk to about my specific problems? Maybe I'm just doing things wrong.
http://forum.corel.com/EN/viewtopic.php?f=90&t=51529
thazooo
- motherboard: MSI Z170 A
- processor: I5 6500
- Video Card: Asus GT730
- sound_card: SB Live Extreme audio
- Hard_Drive_Capacity: 3 TB
- Monitor/Display Make & Model: Dell 2208WFP
- Corel programs: PSP X8, VSP 9.5, ASP 1, 2, 3
My Gripe
Ran into a conversion problem using the .dng files from a Pentax K50.
WB being way off. Camera set to 5000K, asp2 interprets as 6075k.
Loss of detail compared to Pentax supplied converter.
I used Bibble/ASP since 3. It's always done a very good job at keeping the files looking like they came out of the Pentax software, without a lot of adjustments.
This version isn't. I'll assume that it's because of the .dng format rather than .pef.
No upgrading here
Dana
No upgrading here
Dana
Dutchmm
- System_Drive: N/A
- motherboard: Asus 97
- processor: Intel i7 4785T
- Video Card: Onboard Intel
- sound_card: Intel AC97
- Hard_Drive_Capacity: 2.5TB
- Monitor/Display Make & Model: Philips 28"
- Corel programs: ASP 3 Pro (and 2 and 1 before)
@Mipopa
That's quite impressive! I might have a go (just for that set, I am not normally so absent-minded about ISO)
Mike
Mike
brucet
Given limited time to run a full test!!! I've tested ASP2 against ASP1 and Nikon NX-D beta. I tested with very basic adjustments and full tweaking on an individual basis. I can't see a great deal of improvement other than speed in the 64v. In my samples NX-D is a clear winner. (I'm addressing many issues in PSPx6 so I have USM and Noise reduction addressed in PSPx6 and not in the raw conversion. It's my work flow. Old dog new tricks etc).
Now my GRIPE. White balance is still a cot case. Not fixed as far as I can tell. Files out of ASP1 & 2 still have a heavy green tint. Cloudy and Shade settings are broken IMHO. (I haven't tested other white balance presets).
Sorry Corel. No money for an upgrade from me at this stage. I'll keep testing but if I have to fine tune every file for white balance then I'm not interested.
I would like someone else to confirm my findings. I will be more than happy to rescind my gripe if it's my error.
regards
regards
m33
- System_Drive: N/A
- motherboard: Apple
- processor: c2d
- ram: 4GB
- Video Card: ATI1600
- sound_card: Apple
- Hard_Drive_Capacity: 120G
- Monitor/Display Make & Model: 17" Apple
Just updated to AFT2 (Mac OSX x64).
Thank you guys on the forum
Thank you Corel
Thank you Corel
futhark
- System_Drive: N/A
- processor: Core i7 2600k
- Monitor/Display Make & Model: HP ZR22w
On Fedora 19, prior to the rpmrebuild I had to disable the %__prelink_undo_cmd macro in /etc/rpm/macros.prelink. I don't have a good understanding of prelinking but that got me where I wanted.spoilerhead wrote:Parallel install of the ASP2 on rpm machines can be fixed with:
phew :SCode: Select all
rpmrebuild --change-spec-preamble='sed -e "s#^Name:.*#Name: AfterShotPro2#"' --change-spec-provides='sed -e "s#AfterShotPro#AfterShotPro2#"' --notest-install -p AfterShotPro2_2.0.0.133.i386.rpm
fixed output file is then placed in ~/rpmbuild/RPMS/i386/
(worksforme)
With prelinking in place, installing the rebuilt rpm produced the following error:
Code: Select all
error: unpacking of archive failed on file /opt/AfterShotPro/lib/libstdc++.so.6;5380b70b: cpio: Digest mismatch
clifford
- processor: intel i3
- ram: 6gb
I've just taken a look at the 64bit version on fedora running gnome shell.
whats with the windows title bars that overwrite gnomes defaults? Aftershot 1.0 didnt do this and I'd prefer the window to follow my desktop theme.
Steb
- System_Drive: N/A
- processor: Phenom II X6 1090T
- ram: 12 GB
For me the window management for ASP2 is completely broken in Gnome. I cannot get the ASP2 window to the foreground, I cannot get it to the background, I cannot resize it. It is always maximized and the minimize button is the only working button in the window title bar. Really uncomfortable way of working. This is with latest Ubuntu 14.04.clifford wrote:I've just taken a look at the 64bit version on fedora running gnome shell.
spoilerhead
- System_Drive: N/A
- Hard_Drive_Capacity: 13.5TB
got to agree with you there. Can't stand it when an applications thinks it needs it's own look.clifford wrote:whats with the windows title bars that overwrite gnomes defaults? Aftershot 1.0 didnt do this and I'd prefer the window to follow my desktop theme.
my ASP Plugins - donation button ( send beer!
linux,7d, glass and a huge mug of coffee.
If you got any immediate problems with my plugins, don't by shy on contact me on GoogleTalk.
Have you tried a version of ASP that does not have green tint with your NX-D? It seems Corel is taking individual camera to do profiling. And the profile is hardcoded to ASP. If the profiling isn't done right, you are stuck. I have previously done experiments by changing Camera ID in EXIF and I see that each camera has a different setting:brucet wrote:Given limited time to run a full test!!! I've tested ASP2 against ASP1 and Nikon NX-D beta. I tested with very basic adjustments and full tweaking on an individual basis. I can't see a great deal of improvement other than speed in the 64v. In my samples NX-D is a clear winner. (I'm addressing many issues in PSPx6 so I have USM and Noise reduction addressed in PSPx6 and not in the raw conversion. It's my work flow. Old dog new tricks etc).
http://forum.corel.com/EN/viewtopic.php ... 15#p287751
I see some very extreme differences. NEX-3N rendered RAW files have a greenish tint. Color temp values also varies a lot. My workaround is adding an extra step to my workflow - import photos to HDD using exiftool and change the camera ID. Good thing is there are multiple cameras to choose from - from the more accurate NEX-5N (but broken white balance slider) to warmer NEX-6.
brucet
I think one of the problems with comparing ASP 1or 2 with Nikons software is that Nikon knows their NEFs. So ASP is behind to start with. So is every other non Nikon software for that matter. I have been using Bibble and ASP for a while now and always accepted what came out of Bibble/ASP as the correct colour. It wasn't until the release of Nikons NX-D that I started to look at 'other' converters. Wow what a difference. For the first time I could see how 'bad' the ASP white balance was. Even with some fiddling I found it difficult to emulate what NX-D was producing. Simple matter is that what Nikon calls cloudy is not what ASP calls cloudy. What Nikon calls shady is far from ASP's shady. And so it goes. (One caveat is that loading an NEF into NX-D brings with it imbedded data from the Nikon camera. That information is lost going into other converters such as ASP). Regardless all photos still have a green tone to them in ASP.
There are limits to Nikons NX-D. Don't get me wrong. It's not perfect. But if I can't get the white balance right in ASP then all else is a waste of time. Using NX-D gets me great white balance and the ability to fine tune it. 'Almost' everything else I can do in PSPx6. But I need that 'perfect' conversion to start with.
Come on Corel. Fix the white balance issue and the rest will be ok. Well for me it will be.
regards
regards
The same is true for most RAW conversion software I've tried. Canon, ASP, PhotoShop all have slightly different settings for the "presets".brucet wrote:I think one of the problems with comparing ASP 1or 2 with Nikons software is that Nikon knows their NEFs. So ASP is behind to start with. So is every other non Nikon software for that matter. I have been using Bibble and ASP for a while now and always accepted what came out of Bibble/ASP as the correct colour. It wasn't until the release of Nikons NX-D that I started to look at 'other' converters. Wow what a difference. For the first time I could see how 'bad' the ASP white balance was. Even with some fiddling I found it difficult to emulate what NX-D was producing. Simple matter is that what Nikon calls cloudy is not what ASP calls cloudy. What Nikon calls shady is far from ASP's shady. And so it goes.
Nikon made a really stupid move when they decided to start encrypting some of the NEF data... It is your picture, why on earth would they choose to encrypt your data?brucet wrote: (One caveat is that loading an NEF into NX-D brings with it imbedded data from the Nikon camera. That information is lost going into other converters such as ASP)
wongjai888
Thank you to all the serious posters (AFX included) .. I've enjoyed reading the posts and learned a lot!
I'm a photography enthusiast who has always liked ASP's simple, straightforward workflow.
I've used the initial ASP quite a bit, together with ACDSee Pro, Lightroom, Photo Ninja, etc., as I love to play around with these apps.
I've just upgraded to ASP 2, with the hope that Corel will continue to improve the product, which I think is worthwhile supporting.
Cheers!
Cheers!
afx
- System_Drive: N/A
- Video Card: FirePro 4900
I do not think they ever encrypted it.mbellot wrote:Nikon made a really stupid move when they decided to start encrypting some of the NEF data...
They only encoded the WB in a silly annoying proprietary way that took Eric a few days to decipher.
Real encryption is something different
Why would they even keep the file format proprietary?It is your picture, why on earth would they choose to encrypt your data?
cheers
afx
